No-Slip HELP!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco, Aug 6, 2009.
  1. Aug 10, 2009 at 7:38 PM
    #81
    El Taco
    El Taco [OP] Well-Known Member
    STP MN
    thanks drew, ya been a great help.
    any more help please......
  2. Aug 11, 2009 at 6:55 AM
    #82
    98tacoma27
    Ben
    Not Beech Creek
    Can you go back and get the ECU? It's located in the drivers side kick panel. You harness should have the plugs for it already.
  3. Aug 11, 2009 at 6:56 AM
    #83
    98tacoma27
    Ben
    Not Beech Creek
    Hell you may even have the ECU and just don't know it. Did you look?
  4. Aug 11, 2009 at 6:57 AM
    #84
    El Taco
    STP MN
    i can still go back to the junker to get it.
    i just didn't know shit about it and cut it off somewhere where it got to the driver's kick panel.
    what does it look like? this came from a 2001 taco pre trd.
  5. Aug 11, 2009 at 6:58 AM
    #85
    El Taco
    STP MN
    yeah, i looked..............>>>>>>>>>>>>but i don't know if it is the ecu for the elocker or not???
  6. Aug 11, 2009 at 7:14 AM
    #86
    98tacoma27
    Ben
    Not Beech Creek
  7. Aug 11, 2009 at 7:15 AM
    #87
    El Taco
    STP MN
    can't see it...
  8. Aug 11, 2009 at 7:22 AM
    #88
    98tacoma27
    Ben
    Not Beech Creek
    Hows that?
  9. Aug 11, 2009 at 7:26 AM
    #89
    El Taco
    STP MN
    does it say something like........"toyota 4x4 computer".....???
    mine is a prerunner and so is the one i pulled it out of. would other truck have this?
  10. Aug 11, 2009 at 7:38 AM
    #90
    98tacoma27
    Ben
    Not Beech Creek
    If it has an e-locker it has the ecu. The one you pulled it out of should have it then. Your's might because they tend till build the trucks to a cookie cutter design. That's why you will find "extra" plugs in the harness for systems your truck may not have come with.
  11. Aug 11, 2009 at 7:39 AM
    #91
    El Taco
    STP MN
    i've checked already, but i'll check again.....
  12. Aug 11, 2009 at 7:46 AM
    #92
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I have no idea about this stuff but, what I can suggest is right down the part number off your ECU, go down to the junkyard and see if it matches. If it doesn't pick it up before it's gone and continue research. Worst case scenario you throw it on e-bay.
  13. Aug 11, 2009 at 7:52 AM
    #93
    98tacoma27
    Ben
    Not Beech Creek
    He doesn't think he has a 4x4 ECU. He is looking for one.
  14. Aug 11, 2009 at 7:55 AM
    #94
    El Taco
    STP MN
    i just checked............i don't have the elocker ecu.
    any other helpful suggestions....
  15. Aug 11, 2009 at 8:01 AM
    #95
    98tacoma27
    Ben
    Not Beech Creek
    You can get the one out of the donor vehicle. Or You can find away to supply 1.5V to the solenoid through the switch.
  16. Aug 11, 2009 at 11:18 AM
    #96
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    You're in luck. I told my bro about your problem and he went ahead and drew up a schematic for a plug and play harness so you wouldn't need to use any ECU to retrofit an E-locker. Hes going to email it to me and I'm going get the components and solder one up. Would you be interested in testing it on your truck?
  17. Aug 11, 2009 at 11:24 AM
    #97
    98tacoma27
    Ben
    Not Beech Creek
    Drew, I am seeing the solenoid needs 1.5v to operate. Can you verify that?
  18. Aug 11, 2009 at 11:33 AM
    #98
    drew02a
    San Antonio, TX
    By Solenoid, do you mean motor?
  19. Aug 11, 2009 at 11:45 AM
    #99
    98tacoma27
    Ben
    Not Beech Creek
    Yes, motor....:eek:
    I double checked the FSM and diagram. The diagram doesn't specify what the voltage should be. I see in the reassembly instructions it notes using 1.5v to move the motor. I think that is only for alignment purpose as I understand it. All of the voltage ranges in the hints section of the diagram show 9-14v.
  20. Aug 11, 2009 at 11:50 AM
    #100
    drew02a
    San Antonio, TX
    Yeah I can' imagine the motor using anything other than 12v for operation. I'll make sure my brother checked that first though. If this goes well, I might start selling them. :D
