No-Slip HELP!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco, Aug 6, 2009.
  1. Aug 11, 2009 at 11:54 AM
    #101
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    This is the part of the diagram that is important to understand how the locker works.
    It's fairly simple, only 5 wires. 1 ground, 2 supply current to the motor, and the other are connected to a switch that detects when the locker is fully engaged/ disengaged so the motor can be shut off.
  2. Aug 11, 2009 at 11:59 AM
    #102
    98tacoma27
    Ben
    Not Beech Creek
    You could be onto something.
    Yes, wire 2 comes from the e-locker ECU so you don't know exactly what voltage is there unless you physically meter it on a working system. I suspect you are correct though as making it operate using another voltage would be futile. I am thinking using the 1.5v for alignment runs the motor at a slow speed which would allow for easy alignment seeing as the FSM specifies a 5° tolerance.
  3. Aug 11, 2009 at 12:19 PM
    #103
    El Taco
    El Taco [OP] Well-Known Member
    STP MN
    well, just got back from the junker again.
    is this what you guys were talking about, the e-locker ecu......(picture attached)
    i had to cut the wires, they were going somewhere DEEP!!!
    drew, i would like to try that method. BUT......i'll need a picture write-up of how to make the thing. I DO NOT UNDERSTAND THE ELECTRICAL SCHEMATICS AT ALL!!!......I'M A COMPLETE GOOF AT IT!!!
    please let me know...
  4. Aug 11, 2009 at 12:21 PM
    #104
    drew02a
    San Antonio, TX
    If we go my route, I'll build the thing, you'll just have to match the wire colors to plug it in. Should be fairly simple.
  5. Aug 11, 2009 at 12:25 PM
    #105
    El Taco
    STP MN
    yeah, definitely.......anything helps now....
  6. Aug 13, 2009 at 9:10 AM
    #106
    El Taco
    STP MN
    alright, spent a few days reading ALOT of shit.
    i think that dick's diagram is the easiest (correct me if wrong)...... .
    ran to the local radio shack and got:
    a pack of fuses
    an inline fuse holder
    some light bulbs (for fancy-pancy)
    and a DPDT switch
    my main concern is this.......
    i have the stock harness connecting into the elocker itself. how do i know which wires from the stock harness (dick's diagram) go into the switch that i have???
    the switch attached...
  7. Aug 13, 2009 at 9:19 AM
    #107
    drew02a
    San Antonio, TX
    Did your switch come with a diagram?
  8. Aug 13, 2009 at 9:24 AM
    #108
    El Taco
    STP MN
    no. on the side you see it says:
    3 and the other side>>>>>>>>>6
    2 >>>>>>>>>>>>>>>>>>>>>>5
    1 >>>>>>>>>>>>>>>>>>>>>>4
  9. Aug 13, 2009 at 9:26 AM
    #109
    drew02a
    San Antonio, TX
    I'm really not sure. When I need to figure that kind of stuff out I just test the switch with a Multimeter.
  10. Aug 13, 2009 at 9:28 AM
    #110
    El Taco
    STP MN
    i don't have a multimeter......how do you even do that???
  11. Aug 13, 2009 at 9:28 AM
    #111
    drew02a
    San Antonio, TX
    You set it to test for resistance and see which terminals are connected in each position.
  12. Aug 13, 2009 at 9:49 AM
    #112
    drew02a
    San Antonio, TX
    One problem with that dude's design is that it requires you to route power through the firewall and into the cab. That is generally not a good idea, because if there's a short it could start a fire. Best practice is to use a relay to switch the power.
  13. Aug 13, 2009 at 9:55 AM
    #113
    drew02a
    San Antonio, TX
    Here's what the "master electrical engineer" (my bro) had to say about that design:
    ...with that design, the switch wiring is always has high amperage power to it. Not a good idea, plus he's running the motor's power through the built in limit switch in the locker. Toyota doesn't do it that way, and I wouldn't be confident that the limit switch is rated for anything greater than signal voltage. If the shift motor went bad, it could fry the limit switch as well. Using a relay isolates the components and will only allow for low power through the factory limit switch.
  14. Aug 13, 2009 at 10:55 AM
    #114
    El Taco
    STP MN
    okay............
    well, i ran to the local hardware and got a multimeter.....
    and about the whole relay issue.......
    i don't have any experiences or no experiences with electronics on vehicles so help me out......
    so i would need a relay then???.........i did see some at radio shack but don't know if they'd work. would the relays at radio shack work? can i get a relay at the auto-chain stores? what kind of relay should i get?
    thanks.
  15. Aug 13, 2009 at 11:03 AM
    #115
    drew02a
    San Antonio, TX
    The relays from radio shack should work.
    If you can wait a week or 2 I'll mail you a pre-built electrical unit with everything you need to just "plug and play".
  16. Aug 13, 2009 at 11:12 AM
    #116
    98tacoma27
    Ben
    Not Beech Creek
    You are actually going to need two relays. One will engage the lock and the other to disengage the lock. You can control both relays with the single switch.
    The relays should look something like this and have one set of NO (normally open) contacts. They need to have 12VDC coils also.
  17. Aug 13, 2009 at 11:44 AM
    #117
    El Taco
    STP MN
    i'll be going back to school within 2 weeks so i won't have time to be messin' with my truck as i'd like to.
    but whatever you can do man, i appreciate it.
    also, in the mean time, i'll try and see if i can get this to work.....WILL need help from you veterans.......
    98 taco, are there such things a DPDT relays or is there another way of naming/identifying the relays???.............(this proved how much i know about electronics)....
  18. Aug 13, 2009 at 12:11 PM
    #118
    98tacoma27
    Ben
    Not Beech Creek
    Relays work like this: You have a set of open contacts and a set of closed contacts in the same circuit with no power to the coil. When power is applied to the coil, the contacts will then change state, meaning the closed circuit becomes open and the open circuit becomes closed.
    Relays come in a number of configurations. To answer your original question, yes you can get a realy in a DPDT configuration.
    Remember you will need two relays.
  19. Aug 14, 2009 at 10:55 AM
    #119
    drew02a
    San Antonio, TX
    Okay, I should be able to get it mailed to you sometime next week. You should go ahead and install the new axle so all you have to do is wire it up once the parts come in. Make sure the locker works first though.
    I need the following info from you:
    1. Amount of space (depth) available behind where the switch will go, stock location(s).
    2. The length the control wires will have to travel from the connector on the differential, along the axle, along the brake line, along the driver's side frame rail and up into the engine compartment to the brake booster.
  20. Aug 15, 2009 at 8:54 PM
    #120
    El Taco
    STP MN
    hey drew, my bad. BEEN BUSY AS FUCK!!!
    Before anything, honestly I am not sure.
    1. I am not sure, ^^^. Stock should be fine I guess.
    2. I have the stock wiring that runs all the way to the driver's kick panel. What I was thinking of doing was just splicing/soldering your controls to my stock wiring, if that's ok?
    Apologise again, thanks again as well!!!
