No sound coming out of speakers. Restarting truck used to fix it.
Discussion in 'Audio & Video' started by Jhardy!, Jan 23, 2025.
  1. Jan 23, 2025 at 5:01 PM
    Jhardy!
    Jhardy! [OP] Member
    Jacob
    2018 white trd sport Tacoma
    None
    My 2018 Tacoma audio and speakers have no sound. This is not the first instint but I would turn my truck off and on and it would usually fix it this time no. It’s been about 2 days and I’ve tried my fuse box and killing the battery resetting the memory on the screen nothing, I’ve seen countless videos and read all kinds of things but if anyone has any idea help would be much appreciated
  2. Jan 23, 2025 at 6:30 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum, have you by chance removed the radio and checked the connections on the back?
    kahanabob likes this.
  3. Jan 23, 2025 at 7:46 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If all of the connections are good, have tried updating the head unit software? Here is a Toyota link.
    https://www.toyota.com/firmware-updates
    Jhardy![QUOTED][OP] likes this.
  4. Jan 23, 2025 at 8:20 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    What is the audio source you are using? Radio? MP3 player/phone with music on it, if so are you using a USB cable or connecting with Bluetooth? or are you using a thumb drive with music loaded on it? or does your issue affect all of those things?
    Just trying to narrow down whether or not it's the audio source or the hardware in your truck.
  5. Jan 24, 2025 at 4:46 AM
    Jhardy!
    Jhardy! [OP] Member
    Jacob
    None
    I’m just using my phone to blu tooth but also the fm and am radio is not working 0 sound at all I have not made any changes to the vehicle and it has jbl sound system I’ve tried updates and through the general settings but there is not anything to update I’m not very handy and haven’t looked behind the screen to check for wires I have no clue what I’m looking for.
    Phlogiston likes this.
  6. Jan 24, 2025 at 6:43 AM
    bbal
    bbal Well-Known Member
    Assume you’ve already tried the hold down the volume button until the head unit resets…
  7. Jan 24, 2025 at 9:52 AM
    Jhardy!
    Jhardy! [OP] Member
    Jacob
    None
    Yes I have
  8. Jan 24, 2025 at 10:13 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Since you have the JBL system, it sounds like its going to be a issue on the amp side. Checking the amps fuse and power at the amp should be your next step.
    musicisevil and Phlogiston like this.
  9. Jan 24, 2025 at 3:09 PM
    Jhardy!
    Jhardy! [OP] Member
    Jacob
    None
    I have not tried this yet where is the amp located and when I find it what should I do thank you
  10. Jan 24, 2025 at 4:57 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I can tell you it’s behind the passenger side rear seat, but that’s about it
  11. Jan 24, 2025 at 5:34 PM
    5nahalf
    Erik
    Minnesota
    Amp is as musicisevil said, behind the rear seat, its behind the panel with the subwoofer grill.
    There is a fuse that I think is labeled "radio 2". that should be the amp fuse. Try that first before taking the rear trim off.
