No sound from speakers...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BradyT88, Feb 18, 2012.
  1. Feb 18, 2012 at 8:22 PM
    BradyT88
    BradyT88 [OP] Well-Known Member
    So I just got my 05 double cab taco with the jbl system back from the mechanic after a few weeks and the stereo appears to be working, but there is no sound coming out of it no matter what I do. It has a Pioneer AVH-P3200DVD deck in it. I talked with the guy and he said that the battery died on it, but other than that he never touched anything electrical in it. I'm pretty much stumped... Think it could have blown a fuse or something?
  2. Feb 18, 2012 at 8:23 PM
    IndianTaco
    IndianTaco Well-Known Member
    is the volume turned up:cool:
  3. Feb 18, 2012 at 8:25 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Fuse, short in the wiring, bad ground? Your truck is tired of you playing music of today?
  4. Feb 18, 2012 at 8:27 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Why was it in the shop?
  5. Feb 18, 2012 at 8:33 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    x2 :popcorn:
  6. Feb 18, 2012 at 8:41 PM
    BradyT88
    Yes the volume is turned up, the mute is off and so is the att.
    I revved it up and dropped it into gear and it snapped a bunch of teeth on the ring gear in the rear end so I had to get the rear gear and pinion replaced.
  7. Feb 18, 2012 at 8:47 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Does the radio require a code?
  8. Feb 18, 2012 at 8:48 PM
    BradyT88
    I don't think so. What do you mean exactly?
  9. Feb 18, 2012 at 9:08 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Some stereos need a code as an anti theft device. Usually its hondas, and factory radios. But you never know.
    Is the faceplate on all the way?
  10. Feb 18, 2012 at 9:12 PM
    IndianTaco
    have you tried to pull the head unit out and check the wiring?
  11. Feb 18, 2012 at 9:12 PM
    BradyT88
    Ah I see. I don't think it requires a code. Everything about the deck appears to be functioning fine, except that there is no sound from the speakers. The deck even makes the normal little beep sound (I believe its from an internal speaker in the deck) when you use the touch screen.
  12. Feb 18, 2012 at 9:13 PM
    BradyT88
    I haven't got that far yet. I will check it out in the morning.
  13. Feb 19, 2012 at 10:57 AM
    BradyT88
    It is working now. Don't ask me what was wrong but apparently the trick was to take the backseat apart, not to touch anything, just look at it. haha. I took it all apart and was looking at the sub and amp and decided to turn the pickup on to see if maybe only the sub was working and when I tried it everything worked. so I put it all back together and it is still working.
    Before I tore it apart I checked the fuses under the hood and both were fine, so I don't really know what the deal is, unless a clip on the amp was slightly loose an my prying on the back panels reconnected.
    As a side thought hopefully there isn't a short under the floor somewhere that I just happened to unshort, but I had the stereo playing the whole time it didn't burn down yet.
