No sound
Discussion in 'Audio & Video' started by mbecnel, Sep 6, 2015.
  1. Sep 6, 2015 at 12:07 PM
    mbecnel
    mbecnel [OP] New Member
    Louisiana
    1995 4WD Access Cab V6
    In a 95 tacoma receiver, amp and su b. All are getting power but there's no sound. We changed the receiver still doing the same thing. Have no clue what to check.
  2. Sep 7, 2015 at 9:33 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    no sound from just the sub or all the speakers? If its just the sub check the wiring in the box.
  3. Sep 8, 2015 at 5:27 AM
    mbecnel
    Louisiana
    Everything runs thru the sub. This is what we did....checked all fuse and we have power to everything. Changed head unit still no sound, use an external speaker and hooked it directly to head we have sound. Changed the rca cables from head to amp still no sound. Checked speakers and sub with 9v battery all working. Hooked Iphone directly to amp with rca cable no sound......I'm thinking the amp is bad
  4. Sep 8, 2015 at 9:18 AM
    Purpleman
    Anaheim
    15 PreRunner
    Definitely sounds like its the amp. Thats the fucked part about amps, just cause the power light is on doesn't mean its actually functioning.
  5. Sep 10, 2015 at 11:39 AM
    BluePanda
    BluePanda Active Member
    Chad
    Northwest WA
    2015 SR5, 4x4, DCLB, Blue Ribbon
    So this is extremely similar to something that I am experiencing right now as well.
    This probably varies from amp to amp, but for the amp to "look on", i.e. showing the green power light, does it need both power and successful receipt of the remote power on signal, or is just the fact that it has power connected (but no remote signal) enough to show the light?
    I have a DMM in the garage somewhere that I can use to check, but thought I'd see how it is supposed to work first.
  6. Sep 11, 2015 at 11:18 AM
    Purpleman
    Anaheim
    15 PreRunner
    I don't know if it needs both to power on, but it definitely needs "remote power". Remote is the on switch.
