no spark
Discussion in '1st Gen. Tacomas (1995-2004)' started by NavyNate06, Oct 9, 2008.
  1. Oct 9, 2008 at 4:07 AM
    NavyNate06
    NavyNate06 [OP] yeah i fix F/A-18s
    Virginia Beach, VA
    99 Tacoma SR5
    Toytec 3 inch coilovers, OME springs/shocks, Toytec shackles, rattle can paint job, lc headers,
    so i got my engine installed and everything connected. the entire wire harness was hooked up and fluids filled up. i went to crank it over and nothing happened except for the starter turning the engine over. so we pulled the spark plugs to test and come to find out i don't have any spark. i've gone throught the entire toyota diagrams and troubleshooting table. i haven't done anything with the fuel system. i've completely read out the entire ignition wiring harness, the plug wires, i've got new ignition coils and new spark plugs. if anyone has had this problem please lend your help.
  2. Oct 9, 2008 at 4:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are all the fuses good? :confused:
  3. Oct 9, 2008 at 8:16 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    hard to say without being there but do you have the ground strap on back of engine connected to firewall? that will actually keep it from starting since the motor mounts are rubber
  4. Oct 9, 2008 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    dam! I didnt think of that! :eek:
  5. Oct 10, 2008 at 9:54 AM
    NavyNate06
    Virginia Beach, VA
    99 Tacoma SR5
    yup the fuses are all good and i have the grounding straps are all hooked up. there are three of them that i could find. the one on the fire wall, one on the block beside the starter, and another one (the ignition ground) that hooks up to the intake manifold.
  6. Oct 10, 2008 at 5:12 PM
    350TacoZilla
    Hancock MD
    hmmm man I'm out of ideas sorry... its one thing to be there and look at it... another to sit at my keyboard and think "why arent you starting" LOL
  7. Oct 10, 2008 at 5:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It could be a number of things. Is the crank position sensor installed? The ECU is all plugged in propperly? It could also vbe the sender for the oil psi........................:confused:
