No-splice Trailer wiring?
Discussion in '4 Cylinder' started by Rajas, Aug 20, 2012.
  1. Aug 20, 2012 at 10:20 PM
    Rajas
    Rajas [OP] Member
    I am looking for a trailer hitch wiring harness that plugs into the tail lamps without splicing the wires, 2nd gen. Searched and didn't come up with anything, unless I missed something. I cannot use OEM as there is no plug in the main harness on the base model.
  2. Aug 20, 2012 at 10:32 PM
    DBurns
    DBurns Well-Known Member
    Texas
    2012 PreRunner SR5 Double Cab 4cyl
  3. Aug 21, 2012 at 5:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. I bought something similar off Autoanything.com. I've had a kit like that on my 2007 for 5 years now and no issues. Put some dielectric grease in the plug to keep it from corroding.
  4. Aug 21, 2012 at 6:23 AM
    Phil R
    Phil R Scofflaw
    Phil
    Live Oak, FL
    2018 White Tundra SR5
    2012 Base 4x4
    Wiring harness # 118496
    Hidden Hitch # 87581
    Both from etrailer.com
  5. Aug 22, 2012 at 8:08 PM
    Rajas
    Rajas [OP] Member
    Thanks for the responses. I am going to look into all of these and get one on the way!
  6. Aug 23, 2012 at 8:16 AM
    shemp
    shemp Well-Known Member
    All models have the plug. In fact, there are two plugs located behind the driver's kick panel, one of the two is very high up and difficult to reach.
  7. Aug 23, 2012 at 8:20 AM
    jtnyc
    jtnyc Well-Known Member
    Any pics of the location and what the plugs look like?
    I was looking at this kit from a different thread, but wasn't sure if my x-runner, which doesn't have a wiring harness yet, would have the plugs for them.
    http://www.amazon.com/gp/product/B004R3413I/ref=ox_sc_act_title_1?ie=UTF8&smid=A2RA9SXXTGVE9R
  8. Aug 23, 2012 at 9:42 AM
    vstrom
    vstrom Well-Known Member
    Hold on a sec.. so ALL tacomas are pre-wired? I have a base model 2010 Access 4x4 and I didn't see anything but I didn't really tear anything up to look. I had bought plug in type wiring harness a few years ago that seemed good, but then started to screw up all the electrics in the truck. I took it out and everything was fine.
    If my truck IS pre-wired somehow then I'll find the proper wiring this time.
    Need more info..
  9. May 21, 2013 at 8:39 AM
    jchav
    jchav Well-Known Member
    Justin
    Irving Tx
    Red 2.7L 4x4 Manual
    none yet
    Sorry to bump this old thread but does anyone have anymore info on this? I just bought a trailer hitch for my Base model reg cab 4x4 and I would like to wire it up with the factory towing harness. Is this possible or should I just look into the aftermarket products?
  10. May 22, 2013 at 6:43 AM
    Rajas
    Rajas [OP] Member
    There are not plugs on the base model reg cab. Usually the plug is on the harness in the left rear corner I believe. You definitely need aftermarket wiring.
  11. May 23, 2013 at 2:37 PM
    SouthernTaco
    SouthernTaco Well-Known Member
    Scott
    Jasper, GA
    '10 PreRunner SR5 4-banger AC
    Not sure the year of your 2nd gen, but.....
    Plugs are behind the tail lamp covers on my 2010.
    I just installed the following (which is labeled for 2005-2010):
    Hopkins 4-flat wiring kit #43355
    Hopkins mounting bracket #48595
    20 minute easy install, works great.
  12. May 23, 2013 at 2:42 PM
    SouthernTaco
    Scott
    Jasper, GA
  13. May 24, 2013 at 6:22 AM
    jchav
    Justin
    Irving Tx
    Red 2.7L 4x4 Manual
    none yet
    Thanks for the replies. I guess I will go with the aftermarket harness!
