No start after fuel pump replaced
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Y2kbaja, Oct 28, 2020.
  1. Oct 28, 2020 at 11:11 AM
    Y2kbaja
    Y2kbaja [OP] Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Need some help. 2005, I replaced the fuel pump and now truck won’t start. Cranks but no start. I pulled the relay and “discharged” the system per the repair manual prior to removing. Pump is new Toyota pump. Relay is plugged back in. Connector on top of the pump broke the retainer on removal but I’m sure, triple sure, it’s plugged in.
    is there a way to “prime” the pump?
    This was a royal pain in the ass job and I’d rather not pull the tank again. thanks in advance for the help. I’d call my work (Toyota dealer) but I called in sick to finish this repair.
  2. Oct 28, 2020 at 11:15 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Did it through a fault code....
  3. Oct 28, 2020 at 11:17 AM
    Y2kbaja
    Sacramento
    Total Chaos
    I can pull codes but it should be 171? lean condition. Per rm that code will come on when dischargeing the system.
  4. Oct 28, 2020 at 11:22 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    with the key in the Run position can you hear the pump running?
  5. Oct 28, 2020 at 11:24 AM
    IL Capo
    Sidney BC Canada
  6. Oct 28, 2020 at 12:27 PM
    Y2kbaja
    Sacramento
    Total Chaos
    No fuel at either line out of the tank after cranking several minutes. Looks like I’m pulling the tank again. At least all the stupid push clip fittings are loosened.
  7. Oct 28, 2020 at 12:31 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Just going to through this out there...
    If the connector clip broke, then at the very least thats probably going to cause you issues down the road. If not right now
  8. Nov 21, 2020 at 2:27 PM
    choi0706
    choi0706 Member
    figure it out?
  9. Nov 21, 2020 at 6:24 PM
    Y2kbaja
    Sacramento
    Total Chaos
    Yes. Plug into the pump wasn’t fully engaged.
    12TRDTacoma and TireFire like this.
  10. Nov 21, 2020 at 6:32 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You dodo. :rofl:
    Hey at least you found it bro. Good job.
