No start after replacing head gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jkangas004, Nov 3, 2022.
  1. Nov 3, 2022 at 11:03 AM
    jkangas004
    jkangas004 [OP] Member
    Jackson
    2010 2.7 base 4x4 5speed
    None
    I am getting about 200 rpm and it won’t start or backfire if I put starting fluid or carb cleaner in the intake
  2. Nov 3, 2022 at 11:07 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Verify you have power at your coils on Pin 1 Black/Red and ground on Pin 4 White/Black with the key on.
  3. Nov 3, 2022 at 11:34 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Injector pulse will tell you everything
  4. Nov 3, 2022 at 1:17 PM
    jkangas004
    Jackson
    None
    I was getting 12.5 ohms in all 4
  5. Nov 3, 2022 at 1:46 PM
    IvanhoeTaco
    Eastern NC
    No, pulse, like when your cranking the engine you should have pulsing power and or ground at injector.
    Easy way without a noid light is take a taillight bulb and bend the little leads out and put them in injector plug, when cranking if you see the bulb flash that means your cam and crank sensors are doing their job.
  6. Nov 3, 2022 at 1:49 PM
    IvanhoeTaco
    Eastern NC
    Leomania likes this.
