No Start! Engine is getting spark and fuel, fried ECU?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caligula, Aug 15, 2015.
  1. Aug 22, 2015 at 5:21 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    nice work. My IACV also tested out well on the meter and opened and closed when I gave it 12v, but it ended up being bad anyway. Sometimes parts pass most or all of the tests and still don't work quite right. Glad you got it fixed!
  2. Aug 22, 2015 at 7:45 AM
    arifleman
    arifleman Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    Good to hear!
  3. Sep 9, 2015 at 8:59 PM
    Caligula
    Caligula [OP] Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Car isn't starting again.... o_O
    Just had enough juice to get home from the market tonight. Battery warning light was going on and off intermittently last week, now its on constantly. Fix one thing and two more things break.
    Looks like i blew out the alternator, im about to order a new one. Is there a larger model that can be used then the stock 80amp? The stock Denso was $148, so I ordered this TYC aftermarket one for $98 from Amazon:
    http://amzn.com/B002VF5Y9E
    Also for reference, there were M5x20mm bolts with split lock washers i used to install the new IAC, as well as screw head covers to plug the now unused coolant lines:
    I needed to use channel locks to remove the old philips screws after they easily stripped out:
  4. Sep 10, 2015 at 12:12 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Most likely they are JIS screws and using a Phillips screwdriver on them is more likely to strip them. Toyota forums are filled with people complaining about stripping various screws on their cars.
    See this article for more info:
    http://www.agcoauto.com/content/news/p2_articleid/300
  5. Sep 15, 2015 at 8:23 PM
    Caligula
    Los Angeles, CA
    Replaced alternator today. I wanted to note that after having the capacitor replaced on the ECU, as well as cleaning off the connectors for the ECU, o2 sensors, and body harness plug under the drivers seat cured my P0420 code form coming up as well as the dancing fuel gauge.
    Many of these plugs (except the ECU) had what looked like white lithium grease in them. Why and what they were thinking i don't know. I used DeOxit D5 contact cleaner on all the connectors. Its pricy but its good stuff.
    http://www.amazon.com/Hosa-Cable-De...ie=UTF8&qid=1442373581&sr=1-1&keywords=deoxit
    I think this may have been done from the factory, in replacing the original 15 year old alternator, i found the same white grease.
  6. Sep 16, 2015 at 12:51 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Dielectric grease perhaps??
  7. Sep 16, 2015 at 2:02 PM
    Caligula
    Los Angeles, CA
    That was my thought at first, but contrary to what the geniuses at Pepboys say, this grease is not meant to go on contacts, it goes around and over exposed contacts.
    To find all this, it is either something weird from the factory, or there was someone very very stupid tearing up my car before i bought it. Also it looks like lithium grease, ive never seen white dielectric grease.
  8. Sep 16, 2015 at 2:14 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Huh well my driver side headlight connector had a butt load of caked crap, for whatever that's worth.
  9. Sep 16, 2015 at 4:42 PM
    Caligula
    Los Angeles, CA
    Hmm interesting. Ive read of electrolysis degrading differing metals, but plastics? I dunno, all i know is that it shouldn't be there.
  10. Sep 28, 2015 at 11:00 AM
    bry838
    oregon
    What did you do with the coolant lines??
  11. Sep 28, 2015 at 11:47 AM
    Caligula
    Los Angeles, CA
    I removed the line going from the ICV to the round vacuum valve. Then I took the line coming from the block to ICV and put it to the vacuum valve. If i have the need to every remove the manifold, ill probably just remove that whole valve and the extra vacuum lines, as its purpose is to just regulate the coolant going through the ICV.
  12. Sep 28, 2015 at 4:04 PM
    bry838
    oregon
    Whats the purpose of this??
  13. Sep 28, 2015 at 4:17 PM
    Caligula
    Los Angeles, CA
    Because I could.
  14. Sep 28, 2015 at 6:50 PM
    bry838
    oregon
    Gee thanks fur spreadin the knowledge....
  15. Sep 28, 2015 at 7:48 PM
    #35
    Caligula
    Los Angeles, CA
    Like most mods on here, its not going to add 10hp, increase MPG, or get you more pussy. If anything, it makes for a cooler intake, and less clutter in the engine bay. If you were to measure the improvement, it would probably be 0.1hp.
    If you live in a place that regularly gets freezing temperatures, then please dont do this. In theory, the wind chill from the moving cold air could freeze the valve and/or intake into a open position. Otherwise there is no downside. I did the same thing on my BMW M3 just to clean up some clutter. Its coolant valve is controled by a thermovalve in the airbox. Though it should be stated, the BMW M50/S50 engine is very prone to air pockets and overheating, so it makes far more sence on this engine than a Toyota 3RZ engine.
    Nipples plugged
    Thermovalve removed.
    Distribution line returned to head.
  16. Sep 28, 2015 at 11:09 PM
    #36
    bry838
    oregon
    Ah, i see. Thanks for the clarification! Im all for less clutter and what not in the engine bay! But i do live and especially work in a cold weather area so i suppose this mod isnt for me...
