No start, pretty sure it's the key/tumbler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by radioledhead, May 27, 2015.
  1. May 27, 2015 at 9:36 AM
    radioledhead
    radioledhead [OP] New Member
    Battery is fully charged and all - not a juice problem
    this problem first happened a month ago. Turn key, get one click and no cranking action.
    got it started twice that day by pushing it, putting into gear and trying a few times
    the next day a friend jimmied the key in a little, heard a click - the key went in "better" and started every time for a month- no indication of a problem.
    then it happened again, and I cannot figure out how to re-jimmy it...haha
    i have an appointment to get it looked at/fixed
    but looking for pointers on starting it- to get it to dealership
    thank you
  2. May 27, 2015 at 7:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you can turn the key it isn't a tumbler problem.
    When you turn it and it "clicks" that is the solenoid to supply power to the starter motor pulling in. When it does nothing after that it could be several reasons for that:
    1. Battery is too weak to supply enough current to turn the engine.
    2. The battery terminal(s) are loose and have too much resistance so low current to starter.
    3. The solenoid has worn internal contacts and is preventing current flow to the starter motor.
    These are most common.
  3. Jun 22, 2015 at 9:13 AM
    radioledhead
    Thank you jimmy
    I have replaced the battery as it tested as having a bad cell
    it worked great for 2 weeks
    now i am getting the same symptoms again
    also, i'm not sure this is normal, when i have the key in the on position, there is a strange humming from what sounds like down below the engine...
  4. Jun 22, 2015 at 9:17 AM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    I remember I had symptoms similar to this, and it turns out one of my terminals was just a hair loose. And I really do mean just a hair loose. Once I disconnected both terminals and re-tightened them, all was right in the world.
  5. Jun 22, 2015 at 10:30 AM
    radioledhead
    thank you for the tips.
    I kinda thought it could be terminal connector too...
    Will check the solenoid route next if it persists
  6. Jul 23, 2015 at 8:02 AM
    radioledhead
    So after 2 trips to the dealership, a new battery and a few hundred bucks poorer, it was determined that my starter had gone out, at under 64K miles.
    nice.
