No start with good battery
Discussion in 'Technical Chat' started by jp_flynavy, Mar 20, 2019.
  1. Mar 20, 2019 at 9:10 AM
    jp_flynavy
    jp_flynavy [OP] IG: @TrailLimoOverland
    2015 Tacoma DCLB
    Happened for the second time in two week period. Good battery at 12.6v, no lights on dash, no door chime or overhead light on when door is open with the key in. Go to start, no starter engagement.
    Second time, everything was working as it should before engaging the starter, dash lights came on with ign on. Go to start, everything dies, no crank or starter click.
    I will try to look over my battery terminals, although clean and pretty new.
    Battery ground?
    What else I should check. Never had this problem before.
    Stats:
    '15 v6, auto
  2. Mar 20, 2019 at 3:08 PM
    Markcal
    Markcal Well-Known Member
    Possible things to look at as causes:
    1. Broken, loose or disconnected wires in the starting circuit.
    2. If you're not engaged in park or neutral it will cause these symptoms.
    3. Faulty starter solenoid.
    4. Starter motor faulty.
    5. Ignition switch faulty.
    Good luck,
    Mark
  3. Mar 20, 2019 at 8:26 PM
    jp_flynavy
    2015 Tacoma DCLB
    I'll give those a look over. What's weird is that it acts normal until I turn the key and then it looks like a very dead battery start attempt. I am lost.
    I did clean up all my connectors and ground for the battery, well see if the issue comes back.
  4. Mar 20, 2019 at 9:16 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The dome light situation sounds alot to me like something with the battery cables or battery terminals. Have you given them a good wiggle to make sure they're nice and tight?
  5. Mar 21, 2019 at 12:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Measure the Voltage between Battery Positive and the Engine Block
    Has the Battery been load tested ?
    It might read good but when the starter is engaged fall flat
    Any Electrical work done before this started ??
  6. Mar 25, 2019 at 10:35 AM
    truckbeans
    truckbeans Well-Known Member
    Kent
    Sylva, NC
    2018 DCSB OR
    OME 887s, nitrochargers all around, Headstrong progressive add-a-leaf, 255/85-R16 Yokohama Geolandar M/T, Full set RCI skids, RCI sliders, SOS Slimline w/ Smitty 10k winch
    I've had a failing ignition relay present these symptoms on a Tahoe. Easy enough to swap out to rule it out.
