No start
Discussion in '1st Gen. Tacomas (1995-2004)' started by crabshackint, May 8, 2017.
  1. May 8, 2017 at 9:43 AM
    crabshackint
    crabshackint [OP] Member
    Kyle
    2004 4x4 inline 4
    Hello Ladies and Germs,
    This would be my first post about a problem. Hopefully in the right section....
    I live deep in the boons off a long series of dirt roads. The other day, I backed up my taco to load something up, turned the engine off but left the air on. When I returned to turn the engine back on, I heard a click like something went out. Battery has power, terminals are clean... I checked the fuses-all good. I also replaced the starter solenoid-wasn't it. Both of the power settings during key rotation grant power, but not the startup. Power is heard flickering within the starting solenoid but is not reaching the starter. I can't see any loose connections. Any guesses on the next appropriate step for me to take?
    Thanks,
    -Kyle
  2. May 8, 2017 at 9:49 AM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Dear CrabShack,
    Sorry to hear about your Tacoma's failure to start. Did you check for electrical connectivity to the starter? I am assuming you are getting electrical activity to the Tacoma itself when you turn the ignition on. You need to start eliminating possibilities by checking for electrical connectivity to all possible culprits. Check the battery's power while you are doing your checks.
    Good Luck,
    Paul
  3. May 9, 2017 at 8:07 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Could be a bad power cable (the fat one) going to the starter.
    Or a bad/loose ground strap.
  4. May 9, 2017 at 8:11 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Battery. Probably bad cell.
    Your-10Ply-Bud and wilcam47 like this.
  5. May 9, 2017 at 4:12 PM
    Your-10Ply-Bud
    Your-10Ply-Bud Should be fine, not my truck..
    Marshall
    Ontario, Canada
    2001 3RZ 4x4 5spd
    5-Stars/Satoshi 5100's/OME 881's TG AAL/Cooper AT3's
    Yup, if you can check the voltage of the battery you can eliminate that possibility. A bad cell will still power the accessories but won't be able to crank the starter over.
  6. May 9, 2017 at 4:17 PM
    Bishop84
    Bishop84 Well-Known Member
    Battery for sure. A lot of overthinking a simple problem.
    Battery discharged due to light on overnight, won't start because battery discharged. The only possible cause is the obvious one.
    Connections don't corrode and fail overnight, nor do solenoids/starter contacts, they give warning.
  7. May 9, 2017 at 7:40 PM
    Glamisman
    Glamisman Well-Known Member
    if the battery checks out voltage wise tap on the starter with a hammer... tap, not smack. Sometimes the brushes get carbon on them and do not make good contact, the vibration settles them back and make good contact. If that isnt it then I would suspect the starter selinoid. There is a post on here somewhere where all of part #'s are given with a series of stills showing you what to do.
    TacomaJunkie8691 and Dalandser like this.
  8. May 9, 2017 at 9:52 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I had a starter go on me w/o any clear signs. It was on a used and abused civic tho.
    keakar likes this.
  9. May 14, 2017 at 12:25 PM
    crabshackint
    Kyle
    2004 4x4 inline 4
    And the winner is: bad battery cell.
    I had ruled it out because of having just drove it for awhile, minutes prior. The key's ignition position didn't engage the starter whatsoever, not even a lurch. Since it had just been running, I ruled out the possibility of battery death...A suprising, simple (And relieving) diagnosis. A very dead battery.
    Thanks for the assistance gents.
    wilcam47 and Dalandser like this.
  10. May 14, 2017 at 2:09 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Glad you got it figured out! I like having 2 trucks so I can always use another battery to do tests with. It might be worth it to get a used spare just for that purpose.
  11. May 14, 2017 at 2:32 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    ya, batteries (and starters too) are like that, they work great then nothing.
    you think they would give you a sign first but its pretty common to never get any hint of weakness until failure happens.
    glad you got it sorted
    Dalandser likes this.
