No start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe’sTaco, Sep 11, 2022.
  1. Sep 11, 2022 at 7:13 PM
    Joe’sTaco
    Joe’sTaco [OP] Member
    Joe
    2021 Cement Tacoma TRD Sport
    Hi good people; yesterday I tried to start my 2021 TRD Sport Tacoma and it wouldn’t start. I noticed that maybe I hadn’t depressed the brake peddle all the way. I stepped on the brake peddle all way but it wouldn’t start and after several attempts, 4 or 5 times, it started. I figured maybe I’ve got battery trouble but next day I did a load test and it tested ok. Also tested the battery with ohm meter and It reads 12.54 with engine off and 13.85 with engine on. I purchased the truck in May of 2021 and it has 5800k miles on it. Any body have any ideas or suggestions to my problem.
  2. Sep 11, 2022 at 7:16 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    It’s under the bumper to bumper warranty. Call Toyota roadside assistance and have them come sort it out.
    JFriday1 likes this.
  3. Sep 11, 2022 at 7:16 PM
    Bishop84
    Bishop84 Well-Known Member
    First thing is, you don't drive it much, so the battery is probably weak, 12.5 isn't the whole story. Get it tested.
    shakerhood and Chew like this.
  4. Sep 11, 2022 at 7:23 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  5. Sep 11, 2022 at 7:29 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    My truck would not start unless jumped at 33 months into the warranty. Jumped it to get it to my dealer, and got a free new battery. Let your dealer make it right.
  6. Sep 12, 2022 at 6:33 AM
    Joe’sTaco
    Joe
    Thanks all for your responses; the plan is to drive down to the dealer and have them check it out
  7. Sep 12, 2022 at 6:42 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Did you measure voltage on the actual battery post or on the clamp?
    I would check the voltage at the clamp and see if it is lower than the post.
    If it is, remove the clamp and wire brush it and apply some dielectric grease between the two and reassmble.
  8. Sep 12, 2022 at 8:03 AM
    Joe’sTaco
    Joe
    Yes I check both at clamp and post and voltage is the same.
    RyanDCLB likes this.
  9. Sep 14, 2022 at 8:07 AM
    Joe’sTaco
    Joe
    Well guys; took my Tacoma to the dealer and after performing several test, they found the battery was not up to par so they replaced it. Hope this fix the no start problem.
    TacoJoe480 and RyanDCLB like this.
  10. Sep 14, 2022 at 10:30 AM
    TA2016
    Oregon
    You should be okay until the replacement battery dies. My replacement battery is going on 4 years, so Toyota batteries are really hit or miss.
  11. Sep 14, 2022 at 11:01 AM
    Joe’sTaco
    Joe
    We leave in the dessert where it gets extremely hot so the batteries are good for the most three years.
  12. Sep 14, 2022 at 11:19 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Right... here in Phoenix 2 years is about it 3 years is pushing the envelope.
    I would have put a tiny bit of pressure on the gear shift to make sure it was properly seated ( if auto-trans ) otherwise if manual trans I would have depressed
    clutch and moved in and out of some gear then re-engage clutch.
  13. Sep 14, 2022 at 11:33 AM
    Joe’sTaco
    Joe
    I did all that and it wouldn’t start…
