No start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Steelers, Aug 8, 2023.
  1. Aug 8, 2023 at 8:48 AM
    Steelers
    Steelers [OP] Member
    2001 Taco
    I recently bought a2001 2.7 Tacoma and when I went to look at it before purchasing ,the guy I bought it from started it and it ran well. It ran for about 20-30 minutes and ran out of gas. When the guy tried to load truck for delivery it would not start back. Found the ALT fuse was blown and replaced. It will now only run for 2-3 seconds and die. I replaced crank sensor and cam sensor, replaced fuel filter and still not running. Any ideas what I might need to try next? It does have gas in it now but still no luck.
  2. Aug 8, 2023 at 8:49 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hope you kept some of your money as you did not buy it in a no-start condition.
    Bivouac likes this.
  3. Aug 8, 2023 at 8:52 AM
    Steelers
    2001 Taco
    I did buy it because it was running when I went to look at it. I figured something simple, but maybe not.
  4. Aug 8, 2023 at 7:48 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The engine has failed to start since it ran out of fuel correct?
    The pump sucked so much dirt the output has been quite reduced.
    What cause the ALT fuse to open?
    Just what if any codes have you pulled?
    The Crank and Cam sensors failed from running out of gas? You tested them and they no longer worked?
    your battery is fully charged?
  5. Aug 8, 2023 at 8:26 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    It can take a few long cranks to fully purge the fuel line, how long did you try?
    Bivouac likes this.
  6. Aug 10, 2023 at 6:55 AM
    Steelers
    2001 Taco
    Not sure what caused the fuse to open, it happened during the time I was waiting on truck to be delivered. I did try cranking several times until battery died. I will charge battery or change and give that a try. If it doesn’t start I will probably pull pump. I did crack open fuel line while cranking and it was pushing fuel to filter. Can’t get any codes because reader is unable to connect.
  7. Aug 10, 2023 at 7:05 AM
    Clearwater Bill
    Billy
    Largo Florida
    Hope it was a budget friendly purchase! :fingerscrossed:
    And if the truck ever lived in salt country that you did a robust frame inspection.
  8. Aug 10, 2023 at 7:37 AM
    Steelers
    2001 Taco
    Couldn’t pass up the deal and it had a frame replaced a few years ago, frame is great, that was the main reason for buying it.
    Clearwater Bill likes this.
  9. Aug 10, 2023 at 7:53 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Fuel system is pressurized. Fuel pump and filter were snugged up?
    A new gas cap might help.
