No start ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobby123, Sep 27, 2024.
  1. Sep 27, 2024 at 2:21 PM
    bobby123
    bobby123 [OP] Member
    bobby
    Toyota Tacoma v6 2 wd
    My 2017 will crank but wont start it started bucking and running poor. i got acouple codes p21d3 cleared it and then i got p31d1 injectors but i don't know if that's it it wont run at all any ideas i inspected the wiring looks good.
  2. Sep 27, 2024 at 2:23 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the plugs?
  3. Sep 27, 2024 at 2:26 PM
    bobby123
    bobby
  4. Sep 27, 2024 at 2:30 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Make sure the plugs are at least tight and something about checking the injector fuse isn’t blown. Sorry that’s all I’ve got. Maybe @Dm93 has a clue. Good luck. Edit: check under the engine cover for rodent activity, too
  5. Sep 27, 2024 at 2:31 PM
    bobby123
    bobby
    Tks
    Steves104x4 likes this.
  6. Sep 27, 2024 at 2:50 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Has the truck been sitting for awhile? If so, definitely check for rodent chewed wires under the hood.
    If that is the case, sometimes insurance will cover the repair.
    RIX TUX and wilcam47 like this.
  7. Sep 27, 2024 at 2:55 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    You may have to remove airbox cover to look for nests.
  8. Sep 27, 2024 at 3:28 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Welcome to TW!
    kahanabob likes this.
  9. Sep 27, 2024 at 3:41 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Let us know if/what/etc the issue was.
  10. Sep 27, 2024 at 3:52 PM
    bobby123
    bobby
    I dont see any signs while back i had to replace the connector to the cam position sensor one wire was broke but didnt look chewed up
  11. Sep 27, 2024 at 3:53 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    You are off to a good start here, you posted "it cranks but wont start" we know what you are telling us
    so many here post "It rolls over" what the hell does that even mean
    posters here will know what i am talking about.
    Keep us up dated.
    bobby123[OP] likes this.
  12. Sep 27, 2024 at 3:55 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I would start by looking for any noticeable rodent damage around the harnesses. If all looks ok, especially around cylinder 5. I’d pull the plug on cylinder 5 and see how it looks
  13. Sep 27, 2024 at 3:58 PM
    bobby123
    bobby
    would one cyl stop it from runing it doesnt even attempt ?
  14. Sep 28, 2024 at 8:36 AM
    bobby123
    bobby
    It seems im getting the same fault code for different injectors. cant find any damage to the wiring.
  15. Sep 28, 2024 at 11:42 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Might try disconnecting the battery for a few minutes. Shot in the dark but i would at least try, IMO
  16. Sep 28, 2024 at 11:57 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
