no start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yotatime4me, Oct 26, 2024.
  1. Oct 26, 2024 at 5:44 PM
    yotatime4me
    yotatime4me [OP] New Member
    2015 prerunner
    stock
    Hi new here changed out key and ignition switch every thing seems to work as it should cranks over but will not start, Is there a fuse or something im missing?
  2. Oct 26, 2024 at 5:46 PM
    MR5X5
    MR5X5 Well-Known Member
    Did you program the key to the security system? You need too...
  3. Oct 26, 2024 at 5:51 PM
    yotatime4me
    2015 prerunner
    stock
    Thanks how do i go about doing that?
  4. Oct 26, 2024 at 5:51 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you have the 4.0L V6 the truck has an immobilizer, the key has a transponder chip in it that is programmed to the truck, if you changed keys the new ones will need to have the correct transponder chip and they will have to be programmed to the truck.
    As a workaround until you can do that if you have the original key you can wrap a bit of foil around the head of the new key and then hold the head of the original key up to the lock cylinder while you turn the key on and crank the truck.
    MR5X5, winkel and Steves104x4 like this.
  5. Oct 26, 2024 at 6:26 PM
    yotatime4me
    2015 prerunner
    stock
    Thanks Did the foil ran about 10 seconds and quit
  6. Oct 26, 2024 at 6:29 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    May have to keep the key there for a bit after it starts, I'm not sure how long it checks for the chip in the key (I thought it was only at initial power up).
