No start
Discussion in '1st Gen. Tacomas (1995-2004)' started by COtacoma82, Feb 28, 2025.
  1. Feb 28, 2025 at 6:13 PM
    COtacoma82
    COtacoma82 [OP] Member
    2002 Tacoma
    None
    I have a 2002 Tacoma. Today I hit some washboard road and truck died. Now the truck will start and die. I checked and replaced the fuel filter. The fuel pump will pump fuel while cranking but nothing with the key in the on position. Any ideas on what to check. My guess is something like a loose connection and the bumps caused the bad connection. I don’t know where to start.
  2. Feb 28, 2025 at 9:05 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Check that all your wiring harness grounds are properly tightened.
  3. Feb 28, 2025 at 9:57 PM
    Citron
    Citron Well-Known Member
    Oklahoma
    2012 Tacoma TRD Sport
    Does that year have the collision fuel pump shut off?
  4. Feb 28, 2025 at 10:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The fuel pump only turns on when there is a crank signal.
    So that is normal.
    Let me look at some diagrams
  5. Feb 28, 2025 at 10:06 PM
    TnShooter
    Deogee
    STOCK
    What engine and transmission?
  6. Mar 1, 2025 at 4:22 AM
    COtacoma82
    2002 Tacoma
    None
    Engine is 3.4 v6 I’m not sure the transmission at the moment.
  7. Mar 1, 2025 at 5:20 PM
    TnShooter
    Deogee
    STOCK
    Is it Auto or manual?
  8. Mar 1, 2025 at 8:57 PM
    COtacoma82
    2002 Tacoma
    None
    Automatic transmission
  9. Mar 1, 2025 at 9:10 PM
    TnShooter
    Deogee
    STOCK
    How long does it take before the truck dies?
    As soon as you stop cranking, or a few seconds later?
  10. Mar 2, 2025 at 12:26 PM
    COtacoma82
    2002 Tacoma
    None
    Automatic
  11. Mar 2, 2025 at 12:28 PM
    COtacoma82
    2002 Tacoma
    None
    Does as soon as it fires up. And I stop cranking.
  12. Mar 2, 2025 at 12:30 PM
    COtacoma82
    2002 Tacoma
    None
    If I try starting it again it only cranks, but if I shut the key off and try again it will start and die again.
  13. Mar 2, 2025 at 3:25 PM
    COtacoma82
    2002 Tacoma
    None
    Thank you for your help!!! I figured it out finally, the front coil pack came unplugged. Plugged it in and truck runs great again.
    TnShooter likes this.
