No sure if I should be disappointed in this or not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taconator_, Sep 2, 2019.
  1. Sep 2, 2019 at 6:38 PM
    Taconator_
    Taconator_ [OP] IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Awesome, thanks a lot I’ll give it a shot. Because of the nylon, would the red lock-tight still be needed?
  2. Sep 2, 2019 at 6:46 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Wait.....wait.....are you saying that you put red loctite on your leaf spring bolts and nuts? I WOULD NOT recommend this at all. You may have to regrease or change something out in the future. The nylon nuts will be fine or the regular nuts at 87 ft lbs .....NO LOCTITE!
  3. Sep 2, 2019 at 6:58 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Not that I think Dakar is quality stuff, because it’s not. But contrary to popular belief on TW a flat leaf pack under normal load is the absolute best from a performance perspective. So as long as it doesn’t sag any more and it’s proving the support you need, it’s the best place to be.
  4. Sep 2, 2019 at 7:01 PM
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Wait... I’m talking about the u-bolts.. are we talking about the same thing? Because I put a crap ton of red Loctite on them. Are you supposed to? lol.
  5. Sep 2, 2019 at 7:06 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Red loctite is by no means the super strong thread locker that most make it out to be. Little heat from a torch will solve that problem. Its mainly on small screws where you have a real fun time attempting to remove them with the red stuff.
    But yes, torqueing to spec should be plenty fine on its own. Just recheck the torque a few months later.
    Big tall dave likes this.
  6. Sep 2, 2019 at 7:06 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Personally, I don’t use Loctite except on wheel bearing assemblies. But to answer your question, you’ll be fine. It’ll probably just be a bit stubborn if you ever need to remove the U-Bolts again. I just retorque after a couple hundred miles.
    Blue92 likes this.
  7. Sep 2, 2019 at 7:15 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2
    Been using the red shit on things that needed it or not for decades.
    Little machine screws and the like are the only thing that's ever bit me in the ass.
    Sets incredibly fast on the little stuff with tight tolerances too, as IIRC it's the absence of oxygen that makes it set. I even had it kick once on some itty bitty machine screws before I could get the part fully assembled.
  8. Sep 2, 2019 at 7:18 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yup. Its barely noticeable on some of the larger stuff Ive worked on. Just get a bigger impact gun or longer breaker bar. But green or red loctite on tiny set screws can add a ton of time to an otherwise easy job.
  9. Sep 2, 2019 at 8:42 PM
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    I guess that makes sense.
    I believe my 370z had loctite on the shifter and I shattered that thing to pieces. Could not get it off. But it’s a small screw compared to a U-Bolt.
    So... I guess I’ll try the nylon bolts and reduce the torque on them to see if it helps with the flattening of the leaf pack. I’ll probably get a u-bolt flip kit while I’m at it.
    If I want to regain the 1” lost, should I put in a spacer or just add another leaf? Only reason I consider the spacer is because an extra leaf seems like it’ll stiffen it way too much. I just want the rake I had back.. in getting dangerously close to having a bro-lean.
  10. Sep 2, 2019 at 9:02 PM
    ZachPrerunner
    Southeast TN
    The majority of people will probably tell you to get an AAL. If you haul/tow, that would be the better option to give the packs some extra support. I have a 1” ready lift block and haven’t had any issues in the past 3 years with it.
  11. Sep 2, 2019 at 9:14 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Icon RXT pack.
  12. Sep 2, 2019 at 9:30 PM
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Looks like a great option, I’ll definitely look into them. I’ve wanted a 63 swap since foreever. But swapping a leaf pack+archive sound like less of a headache. RXT option 2 looks appealing..
    jerzsubbie likes this.
  13. Sep 2, 2019 at 9:37 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Got mine on 2 years ago, today. Not sagging a bit, still the same height.
  14. Sep 2, 2019 at 9:49 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    "Looks like it sagged" and actual sagging with measurements pre and post lift are two different things.
    Have you taken measurements?
    I've got HD Dakars and I got more lift than I wanted lol
    Also you can always add a leaf to make it the HD pack and you'll definitely gain back the "lost" height.
  15. Sep 2, 2019 at 9:52 PM
    #35
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    How well do they flex?
    Yeah measured about 1” of lost height.
  16. Sep 2, 2019 at 10:17 PM
    #36
    Dr. Emmett Brown
    So you're only on roughly 1" of lift now with Dakar MDs?
  17. Sep 2, 2019 at 10:21 PM
    #37
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    I’ll double check tomorrow just to be sure. I measured 39” when I first installed them (I’m on 33s, measured from the ground to the fender) anyways, I’m at 38” now..
  18. Sep 2, 2019 at 10:24 PM
    #38
    Dr. Emmett Brown
    Oh damn yeah that's definitely sagging. I would personally try adding the extra leaf to make it an HD leaf pack. I only ride with 130 pounds in the bed daily and the ride is nice
  19. Sep 3, 2019 at 3:28 AM
    #39
    crashngiggles
    Jared
    Ubolts are different yes. I was talking about the bolts going through your bushings in your leafs, not the ubolts. Those nylon nuts are for the leaf bolts, not the u bolts.
  20. Sep 3, 2019 at 7:20 AM
    #40
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    I'm sure replacement boots are available ?...
