no tail lights
Discussion in 'Lighting' started by rpmuise, Jul 27, 2011.
  1. Jul 27, 2011 at 6:14 PM
    rpmuise
    rpmuise [OP] Member
    Springfield
    2009 Tacoma 4cyl
    sr5,hsa,stab cntl,pw,pdl,cruise cntl
    I have no tail lights. I have backup lights, directionals and flashers but no running lights. I checked the fuses and they're OK. Headlights work on high and low beam. Anyone have any advice?
    Thanks,
    Rick
  2. Jul 27, 2011 at 6:24 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check to see if you have 12v at the lamp sockets. If you do... Replace the bulbs. If not, check to see if the stalk is working right to turn them on.
  3. Aug 5, 2011 at 10:02 PM
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    humm...I have had several blown tail light fuses for no apparent reason in the last 6,000 miles. Al bulbs are still original equipment. Anyone else have a similar problem?
    Thanks,
    Jeff/silvert
