No tail lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff1974, Dec 18, 2022.
  1. Dec 18, 2022 at 4:03 PM
    Jeff1974
    Jeff1974 [OP] Member
    Jeff
    2019 Tacoma trd
    I blew the tail light fuse under the dash replaced fuse and tail lights worked for a while then blew again I found the wire that was exposed at the rear of truck but now I have no power to the tail light fuse under the dash just wondering how do I get power back the fuse
  2. Dec 18, 2022 at 4:08 PM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    A lot more info is needed
    are these OE or aftermarket? anything else that’s wired to this?
    have you checked the harness all the way to see if anything is cut or chewed?
    Chew and Malvolio like this.
  3. Dec 18, 2022 at 4:16 PM
    Jeff1974
    Jeff
    2019 Tacoma trd
    They are stock no aftermarket and nothing else wired found wire that was exposed at the rear of truck causing the fuse to blow but now I have no power to 7.5 amp fuse under dash everything else works brake and turn signals work fine just no tail lights or tag lights because I have no power to fuse
  4. Dec 18, 2022 at 4:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    What wire at back of truck?
    shakerhood likes this.
  5. Dec 18, 2022 at 4:22 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    OP Must be using talk to type.
  6. Dec 18, 2022 at 4:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The tail light fuse is powered by the tail relay.
    The tail relay is powered by the 120A JB/Alt fuse.
    The tail relay is commanded ON by the Body ECU
  7. Dec 18, 2022 at 4:29 PM
    Jeff1974
    Jeff
    2019 Tacoma trd
    Small green wire that goes to the tail lights that had rubbed on frame and became exposed causing the 7.5 amp fuse to blow fixed wire just don’t have any power to the 7.5 amp fuse trying to figure out why it doesn’t have power
  8. Dec 18, 2022 at 4:31 PM
    Jeff1974
    Jeff
    2019 Tacoma trd
    Thanks I’ll check that fuse to see if that’s the reason I have no power to the 7.5 amp fuse under dash
  9. Dec 18, 2022 at 4:35 PM
    TnShooter
    Deogee
    STOCK
    If that fuse was bad, you’d have a lot more problems than tail lights.
    If your power windows work, the J/B 120A fuse is good :thumbsup:
  10. Dec 18, 2022 at 4:42 PM
    Jeff1974
    Jeff
    2019 Tacoma trd
    Yea my power windows work so I can rule that out then
    TnShooter likes this.
  11. Dec 18, 2022 at 4:45 PM
    TnShooter
    Deogee
    STOCK
    Is the headlight switch On?
    It has to be set to Tail/Park or Headlight.
    Try both positions.
