No taillights or dash lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by BossFan, Feb 21, 2021.
  1. Feb 21, 2021 at 3:28 PM
    BossFan
    BossFan [OP] Well-Known Member
    Frank
    NJ
    03 TRD 4x4 X-Cab MT swap
    Tundra brakes Bilstein 5100s OME springs
    I hooked up my landscape trailer today and turned on the lights and lost my taillights and my dash lights. I thought it might have blown a fuse. I checked all of them and the 7.5 amp one marked STA on the diagram doesn’t work (circled in red). I replaced it, but I still have no power to either side of the amp. And yes, I disconnected the trailer connection before replacing it. Shouldn’t I have power to one side of the fuse, even if it was blown?
  2. Feb 21, 2021 at 3:56 PM
    BossFan
    Frank
    NJ
    I think I answered my own question. That ‘STA’ fuse has nothing to do with the taillights or the dash lights. The fuses fir both of those are under the hood, not in the fuse box under the dash. I will check them out tomorrow. Weird that I lost both of those when they aren’t on the same circuit, right?
  3. Feb 21, 2021 at 5:00 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So it looks like all that should be on the 10A TAIL fuse, which itself is downstream of the 120A ALT fuse. But if you blew the alt fuse, something else is wrong.
  4. Feb 21, 2021 at 5:03 PM
    0xDEADBEEF
    STA fuse is:
    Engine Control (3RZ-FE)
    Engine Control (5VZ-FE)
    Starting (3RZ-FE, 2RZ-FE)
    Starting and Ignition (5VZ-FE)
    Automatic Transmission (2RZ-FE)
    Electronically Controlled Transmission (3RZ-FE)
    Electronically Controlled Transmission (5VZ-FE)
    Engine Control (2RZ-FE)
    Innnteresting.
  5. Feb 22, 2021 at 2:52 PM
    BossFan
    Frank
    NJ
    Turns out it was the TAIL fuse in the fuse box in engine compartment. I replaced it and my taillights and dash lights work again. Now I have to figure out why the trailer would’ve popped the fuse. The trailer is brand new (Oct 2020) and I pulled it with another truck on way home and had no electrical problems. Seems like it has to be in the trailer harness in the Tacoma. Would a bad ground pop the fuse?
  6. Mar 3, 2021 at 2:00 PM
    BossFan
    Frank
    NJ
    Finally figured out my trailer light issue. When they built the trailer, one of the fender screws hit the ‘brown’ wire and was grounding it out. It took a bit of troubleshooting, but at least it was a cheap and easy fix.
    DrZ and tirediron like this.
  7. Mar 3, 2021 at 2:01 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Nice; well done on the trouble-shooting!
  8. Mar 3, 2021 at 4:55 PM
    BossFan
    Frank
    NJ
    Thanks! I need the trailer lights to work properly because I’m going to pick up a new toy on Friday. :)
  9. Sep 4, 2024 at 5:37 AM
    Screaminr1
    Screaminr1 Member
    2023 Tacoma SR
    Are the dash lights and the radio lights on different fuses. I had put in aftermarket stereo system and still using factory radio .
