No taillights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truky!, Dec 31, 2020.
  1. Dec 31, 2020 at 4:58 PM
    Truky!
    Truky! [OP] Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    Installed my Christmas gift, LED tail lights, and I didn't notice it right off, but my tail lights / running lights aren't working. I checked the 7.5 amp tail light fuse, it tested good, I checked the stop fuse under the hood, and that tested ok too. So I put my OEM tail lights back in and they don't work now either...
    Any thoughts??
  2. Dec 31, 2020 at 5:02 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Check grounds first.
  3. Dec 31, 2020 at 5:11 PM
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    Are you getting power to the pigtail?
  4. Dec 31, 2020 at 6:02 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Identify the power wire and ground wire on wire harness and test for power.
    Chew likes this.
  5. Dec 31, 2020 at 6:09 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Are you talking about full tail lights or bulbs? Either way, check inside the connections to see if any of the pins/connectors bent over. Also, what others above stated. Check power to the pigtails with meter and double check fuses with meter.
  6. Dec 31, 2020 at 7:07 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Ok I'll start with hunting the grounds tomorrow
  7. Dec 31, 2020 at 7:17 PM
    Lunabird
    Lunabird Well-Known Member
    Try the 30amp fuse under the hood. Might have touched the ground with the positive
  8. Dec 31, 2020 at 8:19 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Tried that the fuse tested good
  9. Dec 31, 2020 at 11:01 PM
    JEEPNIK
    I assumed he was smart enough to disconnect the battery before removing any wiring.
    If the lights worked then didn’t and no fuses are blown, at some point you’ll be kicking yourself for missing that one itty bitty wire.
  10. Jan 1, 2021 at 5:49 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Already kicking myself...
  11. Jan 1, 2021 at 5:50 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    What kills me is that the stock lights aren't working now
  12. Jan 1, 2021 at 5:59 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    And.... I'm not positive the the running lights ever worked when I installed the lights the first time...
  13. Jan 1, 2021 at 9:38 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    I dont seem to have power going to the tail light sockets, I also noticed that my licenseplate lights are not working, and my tpms is not registering an pressure. I'm not getting a low pressure light, but when I go to the tire pressure window on the dash all it shows isdotted lines where the numbersshouldbe.
  14. Jan 1, 2021 at 9:45 AM
    20tacoma17
    2017 DCLB Sport AT
    You have to be in motion for the TPMS to be working.
  15. Jan 1, 2021 at 9:46 AM
    JEEPNIK
    Did you cut and splice any wiring? When testing current, are you sure you have a good ground?
    Quick ground test. Run a wire from the battery negative to the back of the truck and put your meter from your power supply to the temporary ground.
    If you have voltage then yo have a bad ground. No voltage likely a circuit interrupter is open.
    Do Toyotas have any fusible links in their harness?
  16. Jan 1, 2021 at 10:30 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    ok, thanks
  17. Jan 2, 2021 at 2:05 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    I was pulling and testing the wrong 7.5 amp fuse, I guess I was looking at the fuse panel upside down... alls well...
    shakerhood and Bascoma like this.
  18. Jan 2, 2021 at 2:11 PM
    JEEPNIK
    It happens. Glad all is well.
  19. Jan 2, 2021 at 2:13 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    So what was the problem?
  20. Jan 2, 2021 at 2:25 PM
    20tacoma17
    2017 DCLB Sport AT
    Stuff happens. Glad you found the problem. :hattip:
