No Throttle response for 2/3 pedal, then 100% last 1/3
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01Taco33, Oct 21, 2022.
  1. Oct 21, 2022 at 8:17 AM
    01Taco33
    01Taco33 [OP] New Member
    Riko
    01 Taco 4x4
    I could use some help guys. 01 Taco 3.4. Engine chokes when throttle is first pressed, then picks back up. Then I have no power increase through the first 2/3s of the pedal. I can "tap" pedal and no change until the last 1/3, then wham! Full throttle.
    I've tried TPS, no change.
    It was suggested an O2 sensor, might be the issue?
    It almost feels like a limp mode?
    Please help!
    Thanks guys.
  2. Oct 21, 2022 at 8:22 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Sounds like either a sticking throttle body or a stretched-out throttle cable, possibly both. Give the TB a good cleaning and check the throttle cable for slack.
  3. Oct 21, 2022 at 8:23 AM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    start simple, check maf, tb , iacv, compression oh and stick to oem
  4. Oct 21, 2022 at 8:24 AM
    01Taco33
    Riko
    01 Taco 4x4
    Cleaned throttle body well. Took of intake and it's not sticking. It happened overnight, not gradually.
  5. Oct 21, 2022 at 8:25 AM
    YotaGangYotaGang
    Covina
    is the inside of throttle body sitting right? Fuel filter?
  6. Oct 21, 2022 at 8:27 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Next time you start a thread you could include troubleshooing you have already done...
    Anyways, if it happened that suddenly I would move on to thinking it's a fuel delivery problem.
  7. Oct 21, 2022 at 8:28 AM
    01Taco33
    Riko
    01 Taco 4x4
    Yes it is. And I swapped fuel filter last night. No change. It feels like a sensor, its either on or off.. there's no gradual anything. Power or no power.
  8. Oct 21, 2022 at 8:29 AM
    01Taco33
    Riko
    01 Taco 4x4
    Absolutely I will. I should have included that.
    drizzoh[QUOTED] likes this.
  9. Oct 21, 2022 at 9:16 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Sounds like an improperly adjusted throttle cable- especially since you would have had to take it off to clean the throttle body.
    Have someone push the pedal while you watch it in the engine bay.
    01Taco33[QUOTED][OP] likes this.
  10. Jan 18, 2025 at 12:51 PM
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    2003 Tacoma TRD 4dr Prerunner 4wd conversion
    6”rough country lift, 35” bfg mud terrain, step bars, home made solid 5" bull bar frame mounted top and bottom with gussets ( used an excavator to completely suspend the truck in the air held only by the bull bar), 180k, no rust, no leaks, no cel's, no issues. 4wd conversion with front and rear e-lockers.
    Its none of these answers. Its the iac control on the throttle body. On the other side of the cable on the tb theres a “sensor” that either came unplugged or came loose. It needss adjusted if loose which will set your idle throttle rpm and the motor inside of the tb is whats causing your loss of throttle until the last third of the pedal.. there are two little japonese phillips screws that are a pain to get out without stripping.. use force and carefullness in loosening them or youll drill them out.. it needs set in there at an angle then twisted up until the idle sounds ok.. could also be wiring to that sensor but its 100% that sensor causing this issue..
  11. Jan 18, 2025 at 2:44 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    motor in throttle body is only on 03/04.....consider yourself lucky you dont have those.
    which means only serviceable part is throttle position sensor......which is much better deal than having to buy another $800 TB
    even if its not it.....its not a bad ideal to have a spare
    fuel pump going bad might do this
  12. Jan 19, 2025 at 9:56 AM
    Glamisman
    Glamisman Well-Known Member
    Look at your TPS and tell us if it is a 3 or 4 wire sensor please and is the replacement a Toyota part or aftermarket.
    leid likes this.
  13. Jan 19, 2025 at 10:09 AM
    Clearwater Bill
    Billy
    Largo Florida
    OP hasn't been here in over 2 years. :D
  14. Jan 19, 2025 at 1:53 PM
    O'Silver_Taco
    MD
    I was just correcting Ž@¢K
    the 02's, 03, 04 ......are a specific group
    due to Toyota's evolving genius
