No Throttle Response Randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PLC721, Apr 16, 2013.
  1. Apr 16, 2013 at 7:39 PM
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    So for a while now, its completely random. Driving down the freeway etc my truck loses all throttle response, the engine doesnt die, but it just doesnt do anything. I have to pull over and turn the truck off and re start. It happens seldomly but is very frustrating when it happens. It will happen 4-6 times then be fine for 5 months. Never throws a code or anything. I thought it was the URD MAF calibrator i had, but it has happened since removing it. ANy input would be greatly appreciated.
    Intake is clean
    I have cleaned the MAF
    Engine Mods
    Afe stage3 si Intake
    DTLT Headers
    Stock Muffler
    Just changed spark plugs
    I'm thinking Fuel Filter/Pump?
    02 sensors?
    Vaccum lines?
    11-5-2013
    Update, engine is now Stock and still happening. Have a P0430 and also an 02 sensor code, truck is going to dealer Friday for a full Diagnostics test.
  2. Apr 16, 2013 at 7:59 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I'd call URD Tech Support. Gadget will be able to be able help you.
    No codes pop up from this? Lights? Nothing?
  3. Apr 16, 2013 at 7:59 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Did you have the recall performed at the dealership.. the one that reflashes the PCM and recalibrates the throttle ?
  4. Apr 16, 2013 at 7:59 PM
    PLC721
    Patrick
    Chandler, Az
    I've been trying to reach Gadget for months now.
    Nope no codes, It happened 6 times to Cliff on Saturday
  5. Apr 16, 2013 at 7:59 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    Do you have the traction control system in your '08?
  6. Apr 16, 2013 at 8:00 PM
    PLC721
    Patrick
    Chandler, Az
    Was not aware of one?
  7. Apr 16, 2013 at 8:00 PM
    PLC721
    Patrick
    Chandler, Az
    Nope :cool:
  8. Apr 16, 2013 at 8:03 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Well there goes my theory. haha. The only other thing I can think of now is a faulty ECU or a loose wire some where.
  9. Apr 16, 2013 at 8:05 PM
    PLC721
    Patrick
    Chandler, Az
    I will go check where i removed the Urd MAf Calibrator and make sure everything is properly capped etc but i doubt it has anything to do with that:confused:
  10. Apr 16, 2013 at 8:09 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Didint ur ECU get fried at Toyota once and they replaced it?
  11. Apr 16, 2013 at 8:09 PM
    PLC721
    Patrick
    Chandler, Az
    Nope?
  12. Apr 16, 2013 at 8:10 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    What happened that one time at toyota when they gave you that rental?
  13. Apr 16, 2013 at 8:11 PM
    PLC721
    Patrick
    Chandler, Az
    When they plugged my truck into the Scan Tool it froze the scanner and they had to wait to reset there system or something lol
  14. Apr 16, 2013 at 8:13 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Since its electronic throttle I would look for loose connections that are part of the system. Maybe a reflash could help too.
    GL
  15. Apr 16, 2013 at 8:13 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    I haven't installed one so I don't know what all signals they affect.
    That sounds sketchy...
    I wonder if one of your throttle position sensors might be going bad. I imagine that is unlikely but there are two of them and if they don't match it sends no signal to the throttle body.
  16. Apr 16, 2013 at 8:15 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    singlecabguy (?) had this problem a while back, i think.
  17. Apr 16, 2013 at 8:15 PM
    PLC721
    Patrick
    Chandler, Az
    Throttle Position sensors... ill add that to my list thanks!
  18. Apr 16, 2013 at 9:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The floor mat recall.
    More than 25% throttle, tap the brakes, and the engine dumps to idle.
    If your brake light switch is chattering, it'll randomly kill power.
  19. Apr 16, 2013 at 9:14 PM
    PLC721
    Patrick
    Chandler, Az
    So the reflash makes that not happen?
  20. Apr 16, 2013 at 9:18 PM
    95 taco
    95 taco Battle Born
    i don't think so, if you've had the pedal chop done the ECU will cut power when it senses a certian % of throttle while the brakes are pressed.
