No to low power
Discussion in 'Toyota Trucks & SUVs' started by Jailerdude, Dec 30, 2022.
  1. Dec 30, 2022 at 3:24 PM
    Jailerdude
    Jailerdude [OP] Member
    03 Tacoma 2.7 4x4 Manuel
    Brand new motor
    Hello, I have an 03 Tacoma 4x4 2.7L Manuel. It has 503,000 miles and I just installed a new motor from Frazier Engines. I replaced everything and I mean everything new with the motor swap. All parts were purchased via Oreilly’s except for injector inserts that had to come from Toyota. I just changed oil for the first time on the new motor and after three days I have zero power. I can just make 20 mph with a heavy throttle. I removed all exhaust and replaced the fuel pump with no change. MAF is reading correct and I am only getting 02 codes and a system purge code that has been there for a long time. Other than that no other codes. Check engine light is not flashing and I have correct compression on all cylinders. Plugs are not fouled and all coils are good. No knocking or coolant in the oil.
  2. Dec 30, 2022 at 3:28 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Has it ran good since you put it in….
  3. Dec 30, 2022 at 4:37 PM
    Jailerdude
    Brand new motor
    Yes it ran great like it did when I bought it new. Was an immediate change.
