No TPMS sensors installed? No problem! Answer inside
Discussion in 'Wheels & Tires' started by rcsb jon, Dec 16, 2014.
  1. Dec 16, 2014 at 7:52 AM
    rcsb jon
    rcsb jon [OP] Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    To remedy your TPMS light issues, from not having the sensors installed... This is a $6 fix in takes 5-10 min.
    Go to Harbor Freight and buy this wheel/tire:
    Haul-Master - 10 in. Pneumatic Tire with White Hub - 30900 Deflate the tire
    Unbolt the (2) halves of the wheel
    Insert the TPMS sensors between tube and the tire's sidewall
    -make sure the sensor side (soft side) is against the tube
    -make sure the casing side (soft side) is against the tire
    Reassemble wheel
    -make sure the sensor isn't touching wheel
    Inflate to desired psi...
    -Place behind or under seat in vehicle
    TPMS light should go off within moments
    -no harm to sensors or vehicle
    I had to do this because I upgraded from my original 16" steel wheels to my 16" TRD FJ Trail Teams wheels... there are seperate TPMS sensors for OEM steel and OEM aluminum wheels. The sensors are attached to the wheel at different angle. Similar issues may arise with aftermarket wheels. This is a way to turn the TPMS light off.
  2. Jan 9, 2015 at 9:18 PM
    firstnamemike
    firstnamemike Active Member
    Chicago
    2011 Tacoma Access Cab 2.7L manual
    Old Man Emu N140S NitroCharger Front Strut Set Old Man Emu 2885 Front Coil Set, General Spring rear springs, Bilstein rear shocks
    I'm going to try this.
  3. Jan 9, 2015 at 9:48 PM
    Fonzi25
    Fonzi25 Well-Known Member
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    Hmm interesting Im definitely going to try this
  4. Jan 9, 2015 at 9:55 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    So basically the pipe bomb mod with a wheelbarrow tire
  5. Jan 9, 2015 at 10:08 PM
    Fonzi25
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    What's the pipe bomb mod??
  6. Jan 9, 2015 at 10:10 PM
    OZ-T
    Peter North
    British Columbia
    Same concept as the OP's but with a short pressure vessel made out of PVC pipe instead of the wheelbarrow tire
  7. Jan 9, 2015 at 10:19 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    No thankyou!
    Those tires are good for 2 years at best. Even out of the sun they will lose the air pressure and you will be right back where you started. I really hope people will not go this route. I've used these tires for many projects and they all will either split and blow or just plain go flat.
    For the same money, build the pipe bomb mod.
  8. Jan 9, 2015 at 10:31 PM
    Fonzi25
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    Anyone have a link for the pipe bomb mod sounds like I'm going to be doing that instead
  9. Jan 10, 2015 at 1:26 AM
    OZ-T
    Peter North
    British Columbia
  10. Jan 10, 2015 at 1:30 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    My pipe bomb lasted 2 years, then I sold the truck, probably still will last another 2 years.
  11. Jan 14, 2015 at 11:16 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    This is not the same
    -The tire has a tube in it, that presses against the sensor
    -The pipe bomb mod is rather dangerous, dependent upon your abilities and materials
    Mine has been great behind my seat since June, no pressure loss as of yet.
    Additionally, the tire just being in the cab will greatly increase the longevity.
    ...I also have these wheels/tires on a tricycle for my niece and nephews to ride when they come over. No issues with those since install in 2010
  12. Jan 14, 2015 at 11:19 AM
    Aw9d
    Aw9d That one guy
    Take out gauge cluster
    find TPMS LED
    remove it
    reinstall gauge cluster.
  13. Jan 14, 2015 at 11:19 AM
    OZ-T
    Peter North
    British Columbia
    Hey man , I'm not here to rain on your parade , and I applaud you for coming up with your own solution
    I don't see how having pressure in the pressure rated PVC pipe bomb is any more dangerous than the same pressure in your $6 wheelbarrow tire though
  14. Jan 14, 2015 at 11:23 AM
    Aw9d
    Aw9d That one guy
    OP's idea is great. Pipe Bomb method is great. Both should work the same.
    To me, just remove the damn LED and call it day. While you are in there you can remove the annoying speaker as well. Takes about 30 minutes to remove an LED out of the cluster.
  15. Jan 14, 2015 at 11:24 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    I could care less... lol.
    ...have you seen the lack of ability on forums? People lack some common sense for their personal safety
  16. Jan 15, 2015 at 9:38 AM
    Rexio_Mty
    Rexio_Mty hi everyone
    Monterrey, Mexico
    Tacoma TRD Lunar Rock 2022
    None
    Good info,
    just a quick question, if we use a sensor with tire that you recomend the TPMS sensor will work as regular ??
    Thanks for your quick answer because the original sensor is something expensive with toyota dealer.
  17. Jan 15, 2015 at 9:43 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Yes, you just slide the (4) tpms units in between the tube and the tire (making sure the soft side of the tpms unit is against the tube).
    Then inflate to 30+ psi
    Then place in truck and wait a few sec.. light will go off
  18. Jan 15, 2015 at 9:44 AM
    OZ-T
    Peter North
    British Columbia
    Still don't get how the PVC vessel has any more risk to personal safety than the $6 wheelbarrow tire but whatever
  19. Jan 21, 2015 at 10:08 AM
    BTR
    BTR Well-Known Member
    Mass
    06 Tacoma 4x4 v6
    is there a how to on this? also the location of the tpms led?
