No traction and Rear-Diff Lock randomly came on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toad11b, Jun 3, 2012.
  1. Jun 3, 2012 at 5:02 PM
    Toad11b
    Toad11b [OP] New Member
    Reggie
    South Carolina
    2010 Prerunner TRD Off Road
    Hey guys I'm new here and new to the Tacoma world in general. Just got my first Tacoma about 2 months ago it was a used 2010 with 21k miles on it. Anyway my question is I have been driving it pretty regularly lately about 200 or so miles every day due to my job at the moment. But today when I got home I did a few thing and then needed to go back out and when I went to go I noticed that my traction control was off and wouldn't turn back on, also that the ABS symbol was on, as well as the like for the Rear-Diff Lock. I have no idea what could have caused it and was wondering if you guys had any knowledge that could possibly help. Just to give me an over view of what it could be. Other than that its going back to the dealer tomorrow and getting checked out.
    Sorry this was long winded but I've included some pics of the lights sure it wont help. Also don't know if this is the correct place to put this at or not so if its not my bad.
  2. Jun 3, 2012 at 5:14 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Is it possible you engaged rear locker by accident? Did you try to turn it off?
  3. Jun 3, 2012 at 5:16 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    First thing I would do is pull out the owners manual and start checking fuses for those systems.
    David
  4. Jun 3, 2012 at 5:21 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    You have to be in 4wd low before you can engage the locker but I don't see the 4x4 lights. I'd look at the fuses first.
    /reading is fundamental. You're a prerunner so the above only applies to 4x4's.
  5. Jun 3, 2012 at 5:24 PM
    Canazes9
    David
    Texas
    It's a Prerunner - no 4x4....
    David
  6. Jun 3, 2012 at 5:24 PM
    BlueT
    NorthEast
    He is pre-runner (atleast thats what his sig says)
  7. Jun 3, 2012 at 5:25 PM
    08TacoTrD
    08 TRD Offroad
    Reading is fundamental.
    BlkDakDave likes this.
  8. Jun 3, 2012 at 5:43 PM
    Toad11b
    Reggie
    South Carolina
    No fuses are blown checked those and yes its a pre-runner.
  9. Jun 3, 2012 at 5:56 PM
    Tacoma Mike
    Southern Maine
    Go get the vehicle scanned.
    Toyota's will shutdown related or paired systems in various conditions and the lights showing are a indication that system is affected. Could be something simple.
  10. Jun 6, 2012 at 9:53 PM
    airg
    airg Member
    ariel
    Maui, HI
    4x4 sport
    Mine did the same about a week ago...I thought i accidentally pressed it but when I went to press the buttons it wouldn't shut off...turned my truck off and on still didn't turn off after awhile it did though.....unsure why it did that it has less then 5k...jus gna take it in to get checked! Gears sounded bad from park to rev so idk what's up...
  11. Jun 7, 2012 at 9:52 AM
    Barry70Stang
    Barry70Stang Well-Known Member
    Barry
    West Monroe, La
    TX TRD Tacoma
    Toyota toolbox, Marathon seat covers and Husky liners.......so far!
    My 2012 diff lock engaged going down the interstae at 60 mph:eek: I was no where near the button, and I was in 2 wheel drive. It made a terrible noise. I called the dealership and talked to the shop manager. He told me to call him back if it did it again. So far it has not. Everything still works and there is no noise coming from the rearend, so I've got my fingers crossed that it was a fluke.
  12. Jun 7, 2012 at 10:18 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    how about this first!!
    try the simple things first. Dont recomend the OP anything else until he answers this question. the Locker will turn off all the VSC stuff... turn locker off and VSC will come back on.
    David K likes this.
  13. Jun 7, 2012 at 10:20 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    you need to be going around 5mph to turn it on or off. read your owners manual for a better understanding of the locker
  14. Jun 7, 2012 at 6:35 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    His photos clearly show the Rear Diff. is LOCKED. An Off Road PreRunner can lock it anytime (however Toyota recommends it be used only to get un stuck, up to 5 mph)... and drive it any speed. Turning will be harder since the differential is locked.
    PRESS the RR DIFF LOCK button to disengage.
  15. Jun 7, 2012 at 6:38 PM
    Large
    Large Red
    My 06 did this, button was not pressed and it came on randomly while going ~45 mph.
  16. Jun 8, 2012 at 12:15 PM
    airg
    airg Member
    ariel
    Maui, HI
    4x4 sport
    Just took my truck in today..and good thing too. They said that my r/r
    Drum (something like that) got water in it which it shouldn't..it's rusted and they're going to resurface it...that may have been the cause of all my lights coming on..thank god for warranty
  17. Jun 8, 2012 at 12:39 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Ive only ever turned it on and off while going slow. but when its turned on it turns into this
  18. Jun 8, 2012 at 3:41 PM
    Rexrider
    Rexrider Member
    PA
    2018 Tacoma TRD Off Road (Grey, MT)
    Thank goodness I have a locker. I had no idea it would make my truck airborne!
    All joking aside, that is an freakin' awesome picture
  19. Jun 8, 2012 at 4:02 PM
    David K
    GREAT!
  20. Jun 8, 2012 at 4:08 PM
    dfrugia
    dfrugia Well-Known Member
    Goose
    Roswell, NM
    2012 DC TRD OFF RD 4X4
    Running boards w/steps, Weathertechs
    Regarding the rear locker - you have to under 5mp to engage but can travel highway speeds right?
