No traction and Rear-Diff Lock randomly came on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toad11b, Jun 3, 2012.
  1. Jun 8, 2012 at 4:55 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    You know it is pretty funny how we all (with stock lockers) have this sticker, yet read it differently!
    You can see the word 'switch' is added to clarify between the locker use and the switch use. Don't push the switch when wheels are spinning.. BUT, it does clearly (to me) say use the locker under 5 mph and only to get unstuck... Toyota's recommendation (and yes I know it works at speed and won't blow up).
    Since the locker only works in low range on 4WD Off Roads, you won't be doing highway speeds with it engaged! You are stopped when you engage it, and creep forward to help it lock in place, turning tires to one direction only if it fails pointed straight.
    The 2WD Off Roads don't have that low range speed limit...
  2. Aug 4, 2020 at 10:29 AM
    BryceParker123
    BryceParker123 Member
    Bryce
    2008 Silver Toyota Tacoma TRD
    curious if you figured this out or not
    SR-71A likes this.
  3. Aug 4, 2020 at 10:44 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Bringing an old thread back from the dead huh... :eek:
    OP hasn't been back since Jun 3 2012, the day he posted this thread.. So Im gunna go out on a limb and say he hit the button accidentally lol
  4. Aug 4, 2020 at 3:10 PM
    David K
    His rear locker was engaged (per his dash lights) and that overrides the ABS and traction controls.
  5. Aug 11, 2021 at 7:07 PM
    PincheSirena
    PincheSirena New Member
    My truck did this today. I did not hit the button at all. The last time I touched this button was to get my truck out of the beach area when I almost got stuck, but the light never turned on. And today when pulling out of a parking lot the lights came on (same as this guys the ABS and Diff Lock) and my truck started sliding the back tires. I turned my truck off and then back on and the lights were still there. So I pressed the RR Diff Lock button and it did not turn them off. then as I tried to drive around again I heard a snap and the lights turned off and everything was normal again but now there's a leak next to my front right wheel.
  6. Aug 11, 2021 at 8:27 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    well that can't be good, do you have a prerunner or 4wd?
  7. Aug 11, 2021 at 9:28 PM
    PincheSirena
    I have a prerunner
  8. Aug 11, 2021 at 9:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Before my current 2015 I had a 2011 TRD OR. One day the diff lock light came on randomly driving down the freeway. It didn't blink on quickly, it started out dim and got brighter over about 10-15 seconds.
    Back at the diff there is a plunger switch that tells the dash when the locker is fully engaged. Very simple switch, similar to a reverse light switch on the side of a manual transmission case. I pulled the switch out, worked the plunger up and several times with my thumb, put it back in and never saw the light again. Just something to check
    The trac control and abs gets locked out because the truck thinks the locker is engaged
    SR-71A and 6 gearT444E like this.
  9. Aug 11, 2021 at 9:50 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    If he heard a snap I'd think maybe somehow the shift fork engaged the locker while at speed? And the leak at the front wheel doesn't make sense to me, nothing to leak at the front wheels except for maybe some melted grease if a wheel bearing got smoked.
    b_r_o[QUOTED] likes this.
