no turn signals, won't shift out of park, and more: FIXED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by totmacher, Dec 28, 2011.
  1. Dec 28, 2011 at 7:19 PM
    totmacher
    totmacher [OP] automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Thought I'd give a heads up since the symptoms seemed unrelated.
    While messing with trailer wires near the plug at the truck's bumper, I thought I heard a "click" but didn't worry about it.
    When I got in the truck, I had the following issues (trailer was unplugged when i noticed these):
    -auto trans lever wouldn't move out of Park.
    -turn signals didn't work but hazard flashers did work.
    -A/C and defroster didn't work but fan did blow air out of dash vents (fan switch and temperature switch worked).
    -head lights, fog lights, brake lights, and tail lights worked.
    -when i pushed the lock override to shift out of park, noticed the reverse lights didn't work either.
    The fix:
    - A fuse, 10A. It was the "IGN1" fuse if I remember correctly. The one in the panel below/left of steering wheel.
    Anybody know what that fuse is exactly since it covers so many various things?
    stuckprerunner likes this.
  2. Dec 28, 2011 at 9:40 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    you where hooking/unhooking a trailer? if so, you have a short some where (probably on the trailer. i have the oem tow package and have had my 7 pin plug off of the truck (the whole harness) for the last week and have had no problems.
  3. Dec 28, 2011 at 10:36 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    yup, wires on the trailer had shorted. It just seemed really strange to me that between the 2 fuse panels there are a few fuses for "trailer ___" and various lights but none of those blew. I would've never guessed an IGN fuse. Only found it b/c I started going row by row checking every fuse.
    After just checking the fuses that I thought it should have been but before looking at every fuse, I googled and found where some people (mostly 4runners) had had problems with not being able to shift of out Park too and I didn't like the answers people were giving.
    So thought I'd put this post up just in case it can save someone from going to the dealer thinking some sensor, switch, relay, linkage, etc was bad.
  4. Feb 9, 2013 at 4:05 PM
    newfieby
    newfieby New Member
    brampton ontario
    TRD SPORT
    hello i have the same no turn signals wont shift out of park the dealer told me they would have to change the wiring harness because their a short in the harness from the trailer hitch it is a long wait 2 months for the part
    no truck no Ice fishing :(
  5. Jan 17, 2019 at 10:14 AM
    big j
    big j Member
    Central WI
    08 Taco,TRD OFF ROAD 4x4, d-cab
    Ranch Hand Brush gaurd, Marathon sportsman seat covers, Toyota skid plate, 3"coilovers front , tsb W/aal back
    Was your check engine light on?
  6. Dec 7, 2020 at 3:55 PM
    Reducer
    Reducer New Member
    Same problem, changed 250$ sensor on transmission, did not fix problems, found this and changed the fuse, problem solved, thanks for this post.
  7. Jul 19, 2023 at 9:31 AM
    JW-1
    JW-1 Well-Known Member
    Jeff
    06 Tacoma 4x4
    I realize this is an old post BUT still effective!!! Thanks a million!
    I was about to break down and head to the dealer, then I ran across this.
    Thanks!!!
  8. Jul 19, 2023 at 10:04 AM
    EL DUDE
    EL DUDE Well-Known Member
    My truck wouldn’t start in park, $700 later and it was the park selector thing above the trans
    Small piece of metal and plastic with a bolt or three
    Stealership got me good that day
