no volume control 17 tacoma
Discussion in 'Audio & Video' started by papaw1020, Dec 14, 2024.
  1. Dec 14, 2024 at 2:47 PM
    papaw1020
    papaw1020 [OP] Member
    roger
    2017 tacoma
    none
    i replaced my stock radio with a used jbl gps.lost touch on the old one. first radio put in has no volume control. i can listen on the volume it has, no up nor down on radio or steering wheel. i sent it back and the seller sent another one. either i got the same one back or same problem?? i put the stock back in and every thing works fine????
  2. Dec 14, 2024 at 5:48 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Was your stock one a jbl?
  3. Dec 14, 2024 at 5:52 PM
    papaw1020
    roger
    2017 tacoma
    none
    no , someone said i cant use the jbl.. every thing works fine except i cant adjust sound. sounds fine only you cant adjust
  4. Dec 15, 2024 at 4:59 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    If you don’t have the jbl system, you can’t use the jbl radio
    for the jbl system, all the volume/eq info is sent to the jbl amp and it does all the controls.
  5. Dec 15, 2024 at 6:28 AM
    papaw1020
    roger
    2017 tacoma
    none
