No Way To Lube Propeller Shaft splines on 2012 2.7L Double Cab PreRunner 2WD (?!)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thinkerer, Jun 13, 2014.
  1. Jun 13, 2014 at 12:50 PM
    Thinkerer
    Thinkerer [OP] Member
    Scott
    Central Illinois
    2012 Double Cab PreRunner for the freeway.
    Have 30K on my 2012, went underneath to lube the U Joints and propeller shaft annnnnd...there's no zerk for the splined shaft assembly. It has a flexible boot similar to the CV joint covers on FWD cars, so is it a "never mind" sealed unit? The owner's service manual lists lubing it as well but I'm baffled.
    Yes, I looked everywhere - there's no hidden zerk down in the U joint yoke or some other place.
    ¯\_(ツ)_/¯
