No zerk fittings?!?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dberneski, Feb 15, 2025.
  1. Feb 15, 2025 at 12:09 PM
    Dberneski
    Dberneski [OP] Member
    David
    2020 Cement trd off-road taco
    Tonneau cover, running boards, interior led kit, ridge grapplers 265/75/16
    Hey all, I have a 2020 TRD off-road that is 2wd. I changed the diff fluid today, and while I was underneath the truck, I looked for zerk fittings on the u joints to grease them up. I haven’t found one zerk fitting, are they non serviceable??
  2. Feb 15, 2025 at 12:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They are sealed non-serviceable bearings.
    Now, let the augments of which is "better" begin. :deadhorse:
    Schlappesepple and Chew like this.
  3. Feb 15, 2025 at 12:33 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Hose them down with some WD40 (not)
    BTW, I've yet to find one on my 2019 OR.
  4. Feb 15, 2025 at 12:47 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My '17 Off Road 4x4 has 2 front greasable zerks. The rest are sealed.
    shakerhood likes this.
  5. Feb 15, 2025 at 1:03 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    I change my u-joints every 5,000 miles.
    Fluid Film - I spray that $#!¥ on everything!
    Tocamo, RIX TUX, Phlogiston and 4 others like this.
  6. Feb 15, 2025 at 1:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I vaguely remember 2WD driveshafts have been non-serviceable for a long time, since the 2nd gen days.
  7. Feb 15, 2025 at 1:36 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Yup
  8. Feb 15, 2025 at 1:36 PM
    Schlappesepple
    Joe
    2020 4Runner ORP
    Cheap insurance, right?
  9. Feb 15, 2025 at 1:45 PM
    Buck Henry
    Or maybe the slightly more expensive "peace / piece of mind".
  10. Feb 15, 2025 at 3:20 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    wayne0 likes this.
  11. Feb 15, 2025 at 3:57 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Not a metallurgist guy here but there is thought that non greasable ones are stronger due to not having the grease veins. What's on there (Spicer) is a decent brand and should stand up to wheeling and some abuse.
  12. Feb 15, 2025 at 3:59 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Yep i have 5 on my 2016 ......... So more fun for me.
  13. Feb 15, 2025 at 3:59 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    My 2014 has zerks on the drive shaft ujoints.
  14. Feb 15, 2025 at 4:00 PM
    Bishop84
    Bishop84 Well-Known Member
    From what I've seen they last about the same, if the greaseable is greased.
    Toyota started to eliminate the chances of failures by getting rid of greaseable fittings, it actually started on 2nd gen with a TSB. 3rd gen was slow to it.
    I've run greasable and non-greaseable and prefer non. Both have failed for the same reason.
    My last front set died because I forgot to take the truck out of 4x4 when I was hauling dirt bikes out of a mountain trail.
    Took 2 hours of highway driving to realize it :bananadead:
  15. Feb 15, 2025 at 4:00 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    16’s and 17’s had some, I don’t think any had them past then.
  16. Feb 15, 2025 at 4:26 PM
    Smacky2020
    Bristol, VA
    Yikes, good thing it was the U joints and not the transfer case.
  17. Feb 15, 2025 at 4:28 PM
    Bishop84
    With driveline it's always the weakest point, usually joints. My shaft has play internally but nothing crazy.
    4runners with full time AWD suffer the same problem with time.
    Thankfully u joints are 30$ each and take 30 mins to do.
  18. Feb 15, 2025 at 4:48 PM
    dryheat
    dryheat Well-Known Member
    I've got 2 on my 2019 OR
  19. Feb 15, 2025 at 5:01 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Correct, 4x4 models did, 2WD didn't.
    Williston[QUOTED] likes this.
  20. Feb 15, 2025 at 5:08 PM
    TA2016
    Oregon
    Here is an interesting read.
    “Bottom line on strength: The non-greaseable joint is slightly stronger than a greaseable joint. The exact number, how much stronger, is unknown and we do not believe it to be very significant.
    Bottom line on wear life: A regularly greased greaseable joint will outlive a non-greaseable joint. But a non-greaseable joint will outlive a greaseable joint that does not get greased properly.’
    https://4xshaft.com/blogs/faq/greaseable-vs-non-greaseable-joints-which-is-better?srsltid=AfmBOoqWaqbuFcdhniN_s1Ju_9IBdC1SZCT2cwR1TmLPDxfukjTc4WHA
