No zerks in the stock U-joints?
Discussion in 'Technical Chat' started by ZEROPILOT, May 28, 2014.
  1. May 28, 2014 at 8:08 AM
    ZEROPILOT
    ZEROPILOT [OP] Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    This past weekend I went under my 2009 Tacoma to grease what ever I could grease and found no fittings. Is this normal? My 2 wheel drive has a split drive shaft with three u-joints and no fittings.
  2. May 28, 2014 at 8:12 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    IIRC, the prerunners don't have them. 4WD and maybe some of the 5-lugs do.
  3. May 28, 2014 at 8:12 AM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    It could have the non - serviceable ujoints which don't have any grease fittings.
  4. May 28, 2014 at 8:28 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Pretty much everything is "permanently lubricated" in sealed non-servicable fasion on all modern vehicles.
    The plus side of this is less maintenance, and for poorly maintained vehicles probably a longer component life.
    Downside is shorter component life over a maintainable (regreasable) component.
    Anyway - everything is moving towards "maintenance free" designs. Battery, UCA, etc.
    Bicycles started using sealed bearing packs about 20 years ago. Before that a properly maintained bicycle could last a lifetime. Ahhh progress.
  5. May 28, 2014 at 8:54 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    Yeah. I didn't find a single fitting anywhere.
  6. May 28, 2014 at 10:40 AM
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    did you make sure it is not positioned on the top side?
    move the truck just a wee bit (just put it in neutral and roll it a little) then check again.
  7. May 29, 2014 at 1:47 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    I used my hands to feel around and an inspection mirror. On all three.
  8. May 29, 2014 at 5:35 AM
    jbonecapone
    jbonecapone Member
    Gainesville Texas
    05 PreRunner
    Leveling Kit
    I had to replace mine around 80,000 miles. I replaced with ones with grease zerks. Thanks for reminding me to give them a shot of grease.
  9. May 29, 2014 at 6:09 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Correct. That kind of pisses me off that there are NONE on the pre-runner. However, my wife's Tahoe has 11 zerk fitting and none are on the U-joints...
