No Zerts in Drive line? 2018 TRD 4x4 Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Leon371, Dec 18, 2018.
  1. Dec 18, 2018 at 3:24 PM
    Leon371
    Leon371 [OP] New Member
    2018TRD 4x4 V6 Sport Acess Cab
  2. Dec 18, 2018 at 3:24 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Dec 18, 2018 at 3:25 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    They deleted them after 2016 I believe
  4. Dec 18, 2018 at 3:29 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Is this true? So the 2016 models have them not not anything after that? Same driveline isnt it?
  5. Dec 18, 2018 at 3:30 PM
    Sep1911
    2016 Taco
    2016 definitely has it, 2017 might, but they did discontinue it.
    BSFord[QUOTED] likes this.
  6. Dec 18, 2018 at 3:30 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I have a 2017. Back driveline is sealed, front driveshaft has two zerks (one for each U-Joint).
    Vbpiper, ChronicTaco and shakerhood like this.
  7. Dec 18, 2018 at 3:44 PM
    MitchK
    MitchK Well-Known Member
    16 TRD OR
    I greased mine(2016) last week. It’s somewhat satisfying to watch the old grease splooging out as the new stuff goes in.
    Vbpiper and SpeySquatch like this.
  8. Dec 18, 2018 at 3:49 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  9. Dec 18, 2018 at 3:52 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Front Driveshaft has 2
    Flash1034 and Vbpiper like this.
  10. Dec 18, 2018 at 3:59 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    He’s right there are no Zerts, but they do have Zerks.
    Unchained 5150 likes this.
  11. Dec 18, 2018 at 4:01 PM
    SpeySquatch
    2016 TRD OR DCSB
    What lube are you guys using for your zircs
  12. Dec 18, 2018 at 4:09 PM
    Brianz1001
    Brian
    too much to type
    NLGI No.2
  13. Dec 18, 2018 at 4:10 PM
    BSFord
    2018 TRD Sport 4x4
    I dont think it's supposed to splurge out of the zerks, they should be full but not overflowing, I think you burst them, at least that's what I thought
  14. Dec 18, 2018 at 4:14 PM
    SpeySquatch
    2016 TRD OR DCSB
    There are natural tiny release holes like pinholes
  15. Dec 18, 2018 at 4:15 PM
    Brianz1001
    Brian
    too much to type
    It’s not going to come out the zerk fitting but you can purge it to remove the old hard grease.
  16. Dec 18, 2018 at 6:51 PM
    Sep1911
    2016 Taco
    You're supposed to pump it until u get grease coming out of each cap. This assures you get grease in all parts of the u joint. There is a one way seal built into them so the excess coming out is perfectly normal and a good indication that you've pushed out the old grease as well as whatever contamination that you can get out. It makes a huge fucking mess though and you'll smell something funny for a while as a bit of it will fling on to your exhaust. I do this every oil change. The u joints shouldn't be failing anytime soon with that kind of maintenance.
    Stocklocker likes this.
  17. Dec 18, 2018 at 7:33 PM
    BSFord
    2018 TRD Sport 4x4
    Thanks! Learn something every other day on this forum! Good stuff
    Stocklocker and Vbpiper like this.
  18. Dec 18, 2018 at 8:26 PM
    Stocklocker
    17TRDORDCSBAT
    The manual specs lithium-based grease. Mixing grease can cause a reaction between the dissimilar metals used in the the grease. Calcium, Lithium, Aluminum, and Molybdenum are all metal lubricants used in greases. They don’t mix well as they galvanically corrode each other. Make sure you use a lithium based grease to match what is already in there.
    cwdog, Flash1034 and Vbpiper like this.
