Noah needs help with a flood!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pi314159, May 6, 2012.
  1. May 6, 2012 at 9:28 AM
    Pi314159
    Pi314159 [OP] New Member
    Noah
    MN (for work)
    '08 PreRunner TRD DBL-cab
    HELP!
    My name is Noah (literally), and my '08 Prerunner DBL-Cab TRD is flooding the driver's side floor during hard rains (four times and counting now). This is my first Tacoma and I need help.
    I have:
    • Checked to make sure all the drain channels in and around the front cowl & body are clear - (clean and clear)
    • Checked the A/C air intake - (filer and area are dry)
    • Checked the door seals - (flooded with a hose... dry)
    • Checked the firewall - (visually and w/ a hose)
    • Checked the roof rack mounting area (flooded with a hose... dry)
    • Rear window (dry)
    I'm at my wits end. I love the truck, but I can't figure out where the flooding is coming from. I have personally removed all the seats, carpet, dash, console, etc. (everything I felt confident I could get back together) and flooded the exterior with a hose to check for leaks. Nothing....
    In a last ditch effort before possibly selling the truck I am appealing to you all... the experts... the individuals with a knowledge and passion for Tacomas.
    Please Help,
    Best Regards,
    Noah
    Update: My truck interior is 80% deconstructed again (I'm getting good at it now). I have found that it is wet along the back of the rear storage racks behind the rear seats (would imply the rear window leaks, but it is dry). Also there is a pug under the rear rack that when removed exposes a puddle of water (not sure how to drain this, or how it got there). See picture.
  2. May 6, 2012 at 11:22 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Take it through a car wash and ride in it.
  3. May 6, 2012 at 11:29 AM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    sub'd for outcome. Good luck!
  4. May 6, 2012 at 11:44 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    RHLM (Red Headlight MOD), Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Toytech 2 inch AAL with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker,
    /\ This:cool:
  5. May 6, 2012 at 11:55 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    To sub for later, I'll suggest moving the animals to the other side.
    Water in the rear... First thing I would scrutinize would be 3rd brake light.
  6. May 6, 2012 at 12:02 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Windshield?
  7. May 6, 2012 at 12:05 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Use a shop vac to get all the water out. Make sure everything is really dry. Then go to a car wash or get a hose and soak all the joints, seams, plugs, lights windows, everything and look for water.
  8. May 6, 2012 at 4:21 PM
    Pi314159
    Noah
    MN (for work)
    • Windshield great
    • 3rd brake light is good and fully gasketed
    I'm thinking it's the rear sliding window, but still no active leaking has been observed.
  9. May 6, 2012 at 9:22 PM
    JKD
    JKD Well-Known Member
    3rd brake light, window, and body vent all come to mind in that area.
  10. May 7, 2012 at 7:53 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    3rd brake light seal ! ive had it fail 2 times already.
  11. May 7, 2012 at 7:58 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Do you have a roof rack or something that would allow water in from up top to roll down the backside?
  12. May 16, 2012 at 7:16 PM
    Pi314159
    Noah
    MN (for work)
    The truck interior is completely taken out. Still no clue how/ why it keeps flooding.
    3rd brake light: no leak
    Rear sliding window: no leak
    No roof rack & only the floorboards were wet
    I'm getting awfully irritated with this issue. The truck successfully dried out (carpet up/ air dry). I've tried to artificially flood it several times since its latest leak and still no clue where it comes in. Almost seems like its pooling in the body somewhere (my guess) and flooding into the cab when it get over full.
  13. May 17, 2012 at 2:07 AM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    go to the do it yourself car wash, and spray the shit out of your truck, but have someone inside, give them a soda and tell them to sit in the middle, and watch for leaks. I think there are gromits at the bottom, where the interior cables go out to the back of the bed.
  14. May 17, 2012 at 2:14 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    God? Maybe it's time to start collecting up 2 of every animal. Please leave black flies and mosquitoes off your list. The last Noah really dropped that ball on that one.
    Frank
