Nofords08 build page
Discussion in '2nd Gen. Builds (2005-2015)' started by PLC721, Oct 18, 2010.
  1. Mar 7, 2013 at 10:49 AM
    #2641
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  2. Mar 7, 2013 at 11:21 AM
    #2642
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oooooh yeeeeah. Was gonna put it in there nice and deep like.
  3. Mar 7, 2013 at 12:55 PM
    #2643
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  4. Mar 7, 2013 at 1:04 PM
    #2644
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  5. Mar 7, 2013 at 6:00 PM
    #2645
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Bingo. Exactly what I was referring to. :thumbsup:
  6. Mar 7, 2013 at 6:03 PM
    #2646
    PLC721
    Patrick
    Chandler, Az
    Today was fun even though Josh forgot to bring the lube :rolleyes:
  7. Mar 7, 2013 at 6:04 PM
    #2647
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You had plenty. Don't worry. You like it rough anyways.
  8. Mar 7, 2013 at 6:05 PM
    #2648
    PLC721
    Patrick
    Chandler, Az
    Yes technically i did have more than needed!
  9. Mar 8, 2013 at 11:38 AM
    #2649
    PLC721
    Patrick
    Chandler, Az
  10. Mar 8, 2013 at 11:55 AM
    #2650
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
  11. Mar 8, 2013 at 11:59 AM
    #2651
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  12. Mar 8, 2013 at 12:00 PM
    #2652
    PLC721
    Patrick
    Chandler, Az
    Why what?
  13. Mar 8, 2013 at 12:01 PM
    #2653
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    x2
  14. Mar 8, 2013 at 12:02 PM
    #2654
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Why ask why?
  15. Mar 8, 2013 at 12:02 PM
    #2655
    PLC721
    Patrick
    Chandler, Az
    The Sua kit because i dont need 20" of spring travel, and the shocks because they will build them to have the bypass tubes on the fronts and rears so i have plenty of clearance with my shock hoops
  16. Mar 8, 2013 at 12:06 PM
    #2656
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    The shock choice is fine. I don't really see the need for bypasses tho. Especially if you're doing a limited SUA.
    Are you planning on adding full Bedcage or taller shock hoops down the road?
    The Defined kit is fine, not as set on it as I once was. :cool:
  17. Mar 8, 2013 at 12:09 PM
    #2657
    05TacoRunner
    Peoria, Az
    I know why sua would be beneficial. I just dont see why you would want to drop money on a set of bypasses. I honestly dont think that you would use them to the full potential with your front set up. In my honest opinion I think you should just stick with the smooth body shock and work on re valving it and tuning it for your truck. You will be surprised what a well tuned smooth body will do.
  18. Mar 8, 2013 at 12:11 PM
    #2658
    PLC721
    Patrick
    Chandler, Az
    Well i want the SUA so i can lower the rear of the truck and have more up-travel, i need new shocks for SUA anyways as mine are an odd size so i have to get new shocks anyway when i go SUA, a double by-pass isnt too much more than a smooth body
  19. Mar 8, 2013 at 12:11 PM
    #2659
    PLC721
    Patrick
    Chandler, Az
    From measurements i have taken my current shock hoops will be perfect!
  20. Mar 8, 2013 at 12:12 PM
    #2660
    05TacoRunner
    Peoria, Az
    Why do you need new shocks? Just cycle the suspension and adjust the mounts accordingly.
