Nofords08 build page
Discussion in '2nd Gen. Builds (2005-2015)' started by PLC721, Oct 18, 2010.
  1. Jun 25, 2013 at 9:52 PM
    #3521
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Sweet. That should be quick too right?
    Yeah!!
  2. Jun 25, 2013 at 9:52 PM
    #3522
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    9 bolts total, no time at all lol
  3. Jun 25, 2013 at 9:54 PM
    #3523
    PLC721
    Patrick
    Chandler, Az
    4:30 i when i get off
  4. Jun 25, 2013 at 9:54 PM
    #3524
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oh. Then right on. :)
  5. Jun 25, 2013 at 9:55 PM
    #3525
    PLC721
    Patrick
    Chandler, Az
    Top plate spacer, hub centric rings, snuggle, remove skid plates
  6. Jun 25, 2013 at 9:56 PM
    #3526
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    My top plate.. after measurements to make sure it needs it. Then throw on my hub centric rings, swap my lug nuts, and take off Pats skids.
    Damn you. ^^
  7. Jun 26, 2013 at 2:57 AM
    #3527
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    if I wasnt headed up to Show Low for a badass camping trip tmrw I would totally come hang and help out :p
  8. Jun 26, 2013 at 12:28 PM
    #3528
    PLC721
    Patrick
    Chandler, Az
    I wish i was headed to show low for a bad ass camping trip!
  9. Jun 26, 2013 at 1:02 PM
    #3529
    Manwithoutaplan
    ID
    So GNar in the place!!!!!!!!!
  10. Jun 26, 2013 at 1:13 PM
    #3530
    PLC721
    Patrick
    Chandler, Az
    All day every day! Now that you've had the 4.56's for a while. Still completely happy?
  11. Jun 26, 2013 at 1:17 PM
    #3531
    Manwithoutaplan
    ID
    yea I happy with i have had to adjust to the shitter gas mileage but that is ok. It is really nice on the trail not struggling and burning out my clutch on the littlest things.
  12. Jun 26, 2013 at 10:35 PM
    #3532
    PLC721
    Patrick
    Chandler, Az
    Thanks ECGS!
    Also getting a tune up kit from Camelback Toyota, New Belt, PCV Valve, Plugs, Upper and Lower Radiator Hoses
  13. Jun 27, 2013 at 8:39 AM
    #3533
    Manwithoutaplan
    ID
    I trying to get my truck in tip top shape for road trip at the end of july trying to replace a bunch of crap. Where is PCV valve Located? How where the upper and lower radiator hoses.
  14. Jun 27, 2013 at 8:47 AM
    #3534
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    PCV valve is green, and on the rear of the driver side valve cover. :thumbsup:
  15. Jun 27, 2013 at 8:48 AM
    #3535
    Manwithoutaplan
    ID
    sweet
    thanks :D.
    Maybe i should have made a thread about it :p
  16. Jun 27, 2013 at 8:59 AM
    #3536
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Shhh...maybe he'll never notice. :spy:
  17. Jun 27, 2013 at 9:02 AM
    #3537
    Manwithoutaplan
    ID
  18. Jun 27, 2013 at 9:05 AM
    #3538
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    If we post more... the page will be buried amongst the rest of the useless ramblings that is called Nofords08 build. :)
  19. Jun 27, 2013 at 2:25 PM
    #3539
    PLC721
    Patrick
    Chandler, Az
    This is what my build is all about :goingcrazy:
    Josh i'll see you in like 2 hours :spy:
  20. Jun 27, 2013 at 2:33 PM
    #3540
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :woot: gonna run home. Grab all my parts, change, then head over.
