Nofords08 build page
Discussion in '2nd Gen. Builds (2005-2015)' started by PLC721, Oct 18, 2010.
  1. Sep 23, 2013 at 2:10 PM
    #4061
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    So updating my To-Do list
    Monday 9-30-13: Truck is getting lowered to 2.5" of front lift, too much stress cranked over 3" lift, then heading to the firestone on chandler and priest for an alignment.
    Friday 10-4-13: Replacing CB with a Toyota one.
    Yesterday i replaced the UCA bolt on the passenger side, was defiantly bent and must have affected my alignment, not to mention the front is making less noise now. Luckily it came out easily for having a nice bend on it.
    Then sit tight until next semester!
  2. Sep 23, 2013 at 2:18 PM
    #4062
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
  3. Sep 23, 2013 at 2:27 PM
    #4063
    PLC721
    Patrick
    Chandler, Az
    Lol i havent even tested my fancy "white" wax :face palm:
  4. Sep 23, 2013 at 2:37 PM
    #4064
    PLC721
    Patrick
    Chandler, Az
    iPhone 4 vs 5s Camera
  5. Sep 23, 2013 at 2:39 PM
    #4065
    JTS2016TACO
    Jamie
    Chandler, AZ
    you got the 5s? oh and 7 at somburros be there
  6. Sep 23, 2013 at 2:39 PM
    #4066
    PLC721
    Patrick
    Chandler, Az
    Yeah i got it the day it came out!
  7. Sep 23, 2013 at 2:40 PM
    #4067
    JTS2016TACO
    Jamie
    Chandler, AZ
    I want to see it just to see the differences from my phone
  8. Sep 23, 2013 at 2:55 PM
    #4068
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
  9. Sep 23, 2013 at 2:57 PM
    #4069
    PLC721
    Patrick
    Chandler, Az
    LMAO Jason!
  10. Sep 23, 2013 at 2:58 PM
    #4070
    JTS2016TACO
    Jamie
    Chandler, AZ
  11. Sep 23, 2013 at 3:40 PM
    #4071
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Lol!
    When you drop you're preload spray those threads out and lube em so you can turn that collar. Unless you're taking em to a shop fora wall mount compressor. I did come up with a super sketch system to make my collar adjustments really easy but i'm not sure id do it again lol.
  12. Sep 23, 2013 at 3:46 PM
    #4072
    PLC721
    Patrick
    Chandler, Az
    Lol lets hear your sketch system!
  13. Sep 23, 2013 at 5:03 PM
    #4073
    SconnieHailer
    Marc
    Get ur truck on jacks up front. pull your wheel off. Get ur jack under the LCA and jack up the LCA compressing the spring until it starts to just barely lift the truck off the jacks. Then use ratchet straps like coil compressors and just get them snug or a few clicks tight on the coils. Then let the jack down and your straps will hold the coil leaving just about all the pressure off the collar. MUST HAVE GOOD RATCHET STRAPS!!!
  14. Sep 23, 2013 at 5:04 PM
    #4074
    PLC721
    Patrick
    Chandler, Az
    I've heard of people doing that before lol
  15. Sep 23, 2013 at 5:07 PM
    #4075
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Sounds similar to what I did to swap my coils. Lol
  16. Sep 23, 2013 at 5:08 PM
    #4076
    PLC721
    Patrick
    Chandler, Az
    ^^ Thats where ive heard of someone doing that!
  17. Sep 23, 2013 at 5:09 PM
    #4077
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hahaha. Its different for mine tho.. but same concept. Just relieving the pressure off the coil.
  18. Sep 23, 2013 at 5:12 PM
    #4078
    PLC721
    Patrick
    Chandler, Az
    We need to go to Sedona now that its cooling off Josh
  19. Sep 23, 2013 at 5:20 PM
    #4079
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I agree. :)
  20. Sep 25, 2013 at 12:01 PM
    #4080
    PLC721
    Patrick
    Chandler, Az
    Maybe Oct 5th?
