Nofords08 build page
Discussion in '2nd Gen. Builds (2005-2015)' started by PLC721, Oct 18, 2010.
  1. Nov 5, 2013 at 4:44 PM
    #4241
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    All sensors are tight, and the cab has always leaked when it rains :(
  2. Nov 5, 2013 at 4:52 PM
    #4242
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    You should have got it fix after we went snowboarding when you were under warranty. :/
  3. Nov 5, 2013 at 5:07 PM
    #4243
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    When was the windshield last replaced on your truck?
  4. Nov 5, 2013 at 6:05 PM
    #4244
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Pull your carpet back and crawl under the dash. Then have someone run a water hose across the cowl while you look for the leak
  5. Nov 5, 2013 at 6:21 PM
    #4245
    PLC721
    Patrick
    Chandler, Az
    If you kick me in the balls next time we hang out i will deserve it
    Uhm maybe 2-3 years ago
    Thats actually a good idea, can i borrow the 02 sim so i can get through emissions?
  6. Nov 6, 2013 at 5:26 AM
    #4246
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Good idea. Then silicon that area up. Cut pinch weld perhaps? IDK.
    I have one that is a wire in, if you are interested.
    Was it the front sensor or rear sensor that was loose? Don't remember.
  7. Nov 6, 2013 at 6:18 AM
    #4247
    PLC721
    Patrick
    Chandler, Az
    It was the front sensor that was loose, what do you mean wire in?
  8. Nov 6, 2013 at 7:29 AM
    #4248
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My O2 sim is the style prior to the plug n play style. It has to be wired in.
  9. Nov 6, 2013 at 7:40 AM
    #4249
    PLC721
    Patrick
    Chandler, Az
    Sweet gotcha, I'll borrow Jason's to get trough emissions that way I'm not on a bad time crunch. Time to renew the tags for another 2 years. Lol
  10. Nov 8, 2013 at 7:47 AM
    #4250
    PLC721
    Patrick
    Chandler, Az
    Fingers crossed for me peeps on my way to the dealer!
  11. Nov 12, 2013 at 1:55 PM
    #4251
    PLC721
    Patrick
    Chandler, Az
  12. Nov 12, 2013 at 1:57 PM
    #4252
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    I like it. They look sweet with plate bumpers
  13. Nov 12, 2013 at 1:57 PM
    #4253
    Manwithoutaplan
    ID
    Trading your truck in for raptor :spy:
  14. Nov 12, 2013 at 1:58 PM
    #4254
    JuansTaco
    Juan
    gilbert az
  15. Nov 12, 2013 at 1:58 PM
    #4255
    PLC721
    Patrick
    Chandler, Az
    I want to start fresh and do everything right the first time. Bumpers, and kings all the way around with skids and sliders. Black wheels and 295 tires
  16. Nov 12, 2013 at 1:59 PM
    #4256
    Manwithoutaplan
    ID
    well then just take off all your parts and put them back on.
  17. Nov 12, 2013 at 2:01 PM
    #4257
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Uh oh. You got the bug again. Lol
    I did too tho yesterday at the dealer while Sebastian did my brakes. Was looking at the sexiest The dead I had ever seen. Then looked at 4runners. Lol. Then the new tacomas. Had to leave... I figure as long as a stay away from dealers im ok. Otherwise I want a new vehicle.
    So... stay away from dealers!
  18. Nov 12, 2013 at 2:03 PM
    #4258
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    :bananadead:
    You are giving up way to easy. Need one of your local buddy's to give you a nut punch.
  19. Nov 12, 2013 at 2:05 PM
    #4259
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ill do it!! Little bastard lives right down the street from me.
    Ill be over in a minute Patty Cakes. Then I after I slap your nuts silly... you can help take my rear fenders off so I can put new clips in. :D
  20. Nov 12, 2013 at 2:07 PM
    #4260
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I would love todo that also especially all experience/knowledge I have now . But I don't think I can ever give up my taco only if it gets totaled and can't drive no more. its got to much sentimental value.
