Nofords08 build page
Discussion in '2nd Gen. Builds (2005-2015)' started by PLC721, Oct 18, 2010.
  1. Nov 12, 2013 at 9:00 PM
    #4301
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Ya, roof rack I'm sure doesn't help but the wind deflector makes up some. It's just a heavy turd I guess.
    Ya, that was on the odo which is not totally correct, it's prob reading a bit high actually because with the tire and gear combo I'm a bit lower geared than stock
  2. Nov 12, 2013 at 9:01 PM
    #4302
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Tyler whats the turn around time on your standard rear bumper?
  3. Nov 12, 2013 at 9:02 PM
    #4303
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Right now about 12 weeks :(
  4. Nov 12, 2013 at 9:05 PM
    #4304
    PLC721
    Patrick
    Chandler, Az
    Busy man!
  5. Nov 13, 2013 at 8:23 AM
    #4305
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Gearing doesnt effect the odometer because the speed and mileage are read off wheel speed sensors at the wheels not the transmission. Tire size will effect it though. Calculating tire size you are actually traveling 7.4% farther than what your odometer shows. So lets say your odometer says 220. Multiply that by 1.074 and that gives 236.28 which is closer to the mileage you actually traveled.
    If you were to calculate mileage off of 220 with 17 gal of gas used you would get 12.8 mpg. If you do the math with the calculated mileage and 17 gal you get 13.9. I just found you 1 mpg. I bet if you took off the rack you would gain at least 2 mpgs. It is amazing how bad they hurt mpgs.
    Edit: Would have continued this last night but my laptop died.
  6. Nov 13, 2013 at 8:40 AM
    #4306
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Thanks, I never really though ab0out where the Odo picks up, I as thinking when I regeared it changed. Thanks, I'm almost Prius status now
  7. Nov 13, 2013 at 8:44 AM
    #4307
    05TacoRunner
    Peoria, Az
    If you had a manual trans I believe it would as I am pretty sure it picks up off the out put shaft of the trans. I think your downfall is the weight and rack.
  8. Nov 13, 2013 at 8:47 AM
    #4308
    PLC721
    Patrick
    Chandler, Az
    ^yep you are correct sir
  9. Nov 13, 2013 at 9:38 AM
    #4309
    PLC721
    Patrick
    Chandler, Az
    Okay Mr.Moose cyber ball slapped me straight last night. I'd miss my taco too much
    Deatschworks 320 LPH fuel pump
    Fx-r Projectors
    Mcneil Bedsides
    Pelfrey Bumper
    Stealth 8's
    And some other msc items here and there
    God thats an expensive list.... but still cheaper than a new 4runner and modding it lol
  10. Nov 13, 2013 at 9:48 AM
    #4310
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  11. Nov 13, 2013 at 9:51 AM
    #4311
    Aw9d
    Aw9d That one guy
    didn't you sell your FX-r's? Are you doing them again?
  12. Nov 13, 2013 at 9:53 AM
    #4312
    PLC721
    Patrick
    Chandler, Az
    Yeah I sold them. But I'm doing another set and getting the bigger lens with a sweet shroud set up :spy:
  13. Nov 13, 2013 at 9:56 AM
    #4313
    Aw9d
    Aw9d That one guy
    :thumbsup:
    I have to redo my retro as well. The driver side almost has no output. I looked at it and all the inside chrome has pretty much fell off.. So going to re-do the entire thing again as soon as Tiff gets a job.
  14. Nov 13, 2013 at 10:01 AM
    #4314
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    Good job Josh :thumbsup:
  15. Nov 13, 2013 at 10:09 AM
    #4315
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
  16. Nov 13, 2013 at 10:59 AM
    #4316
    PLC721
    Patrick
    Chandler, Az
    I miss the cut off line and hid's too much, plus how unique they look
  17. Nov 13, 2013 at 11:34 AM
    #4317
    JTS2016TACO
    Jamie
    Chandler, AZ
    I kind of want to do FX-r's
  18. Nov 13, 2013 at 11:39 AM
    #4318
    PLC721
    Patrick
    Chandler, Az
    Wait until aftermarket housings come out?
  19. Nov 13, 2013 at 11:40 AM
    #4319
    JTS2016TACO
    Jamie
    Chandler, AZ
    Yes sir haha no way I'm gonna put them in the scratched housing
  20. Nov 13, 2013 at 11:41 AM
    #4320
    PLC721
    Patrick
    Chandler, Az
