Nofords08 build page
Discussion in '2nd Gen. Builds (2005-2015)' started by PLC721, Oct 18, 2010.
  1. Feb 9, 2014 at 6:00 PM
    #4861
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Awesome thanks for confirming Krish!
  2. Feb 9, 2014 at 6:13 PM
    #4862
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    x2 i have anzo's. good price. i need to get retro's fxr. school. keeps my mod money near zero... i think ill get TRD exhaust next. and roll Black Depo headlights. temporarily
  3. Feb 9, 2014 at 6:23 PM
    #4863
    BradyT88
    BradyT88 Well-Known Member
    So who had the gussets and couldn't fit the headers then?
  4. Feb 9, 2014 at 6:24 PM
    #4864
    PLC721
    Patrick
    Chandler, Az
    Not sure who it was. Gadget just said they won't work with the gusset
  5. Feb 9, 2014 at 6:26 PM
    #4865
    BradyT88
    Yeah I saw that on the spec page for them on their site.
  6. Feb 10, 2014 at 5:49 AM
    #4866
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There was also a time when he said that TRD exhaust wouldn't fit the XR. Ended up that it was because the tip wasn't flush with the body kit. Point is, "fit" could be relative.
  7. Feb 10, 2014 at 5:50 AM
    #4867
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  8. Feb 10, 2014 at 6:04 AM
    #4868
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    He also said I needed to lift the engine to install my headers. not so
  9. Feb 10, 2014 at 7:28 AM
    #4869
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ahh yes. Forgot about that one.
    They are offering built, sleeved, stroked short blocks now though. Just swap one in with headers already installed. Problem solved. ;)
  10. Feb 10, 2014 at 8:12 AM
    #4870
    PLC721
    Patrick
    Chandler, Az
    Good to know, i really want to do the exhaust again but do it right this time:rolleyes:
  11. Feb 10, 2014 at 8:37 AM
    #4871
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    :spy:
  12. Feb 10, 2014 at 8:39 AM
    #4872
    PLC721
    Patrick
    Chandler, Az
    You already know whats up? Any word from Dirt Designs yet?
  13. Feb 10, 2014 at 8:39 AM
    #4873
    BradyT88
    Well this is encouraging :D Now if I just had the money for the headers. haha I am kind of waiting to see if he comes out with an equal length y-pipe for 4wds as well though. I could use a new y-pipe more than headers at the moment. My y-pipe is a bit mangled...
  14. Feb 10, 2014 at 8:39 AM
    #4874
    PLC721
    Patrick
    Chandler, Az
    x2 mine is kinda pinched
  15. Feb 10, 2014 at 8:40 AM
    #4875
    JTS2016TACO
    Jamie
    Chandler, AZ
    Not yet but ill text you when they respond :)
  16. Feb 10, 2014 at 8:41 AM
    #4876
    BradyT88
    Yep. haha Toyota picked an awful spot for the y-pipe. It's safe now that I have my tcase skid but the damage was already done...
  17. Feb 10, 2014 at 8:44 AM
    #4877
    PLC721
    Patrick
    Chandler, Az
    Phil i see you creeping, wheres that abs plastic!!
  18. Feb 10, 2014 at 8:49 AM
    #4878
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    You didn see anything. And I got nothing home slice. Nobody that knows anything either.
  19. Feb 10, 2014 at 8:50 AM
    #4879
    PLC721
    Patrick
    Chandler, Az
    I actually found some on Amazon lol
  20. Feb 10, 2014 at 8:51 AM
    #4880
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Then why you asking me lol
