Nofords08 build page
Discussion in '2nd Gen. Builds (2005-2015)' started by PLC721, Oct 18, 2010.
  1. Jan 9, 2015 at 4:10 PM
    #5841
    BradyT88
    BradyT88 Well-Known Member
    My backup camera is aftermarket.
    I don't have any other suggestions...
  2. Jan 9, 2015 at 4:31 PM
    #5842
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I meant I don't have one or lights tied into back up lights
  3. Jan 9, 2015 at 8:22 PM
    #5843
    336
    336 Well-Known Member
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    one of my favorite builds!
    check mine out brother! it's about to start coming along!
  4. Jan 9, 2015 at 10:55 PM
    #5844
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    Last night I did notice that when you used your turn signals your reverse lights flashed too. Could it have something to do with that?
  5. Jan 10, 2015 at 6:25 AM
    #5845
    PLC721
    Patrick
    Chandler, Az
    Oh that's pretty odd, when It happened yeaterday it was after going around a corner and I had used my turn signal
  6. Jan 10, 2015 at 9:23 PM
    #5846
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    guys - this is likely a grounding problem. you turn on one thing and the return current is coming back into another lamp or device. check the screws that hold ground wires to the frame or chassis. there needs to be a good electrical connection to the chassis, and corrosion or loose connection, wire about to break off will show up as a odd problem like you describe.
  7. Jan 10, 2015 at 9:27 PM
    #5847
    PLC721
    Patrick
    Chandler, Az
    It's only my right blinker that does it, right blinker on, R is flashing on the dash.
  8. Jan 11, 2015 at 9:43 PM
    #5848
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Blinker fluid is probably low
  9. Jan 11, 2015 at 9:44 PM
    #5849
    PLC721
    Patrick
    Chandler, Az
    That only makes sense
    But seriously im stumped lol will work on the truck tomorrow and see what i can do
  10. Jan 12, 2015 at 7:56 AM
    #5850
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    '16 T4R Trail Premium, 08 AC 4x4 6spd(Sold)
    Some, Suspension and stuff, tires, maybeh some armor.
    Did you get that plugged in to see if it worked? i am glad we could help each other out in this case!
  11. Jan 12, 2015 at 8:38 AM
    #5851
    PLC721
    Patrick
    Chandler, Az
    No I'll have to cut and splice the wires, turns out the plugs I have behind the dash are still jbl, not a biggie as I still need to wait to purchase some other audio upgrades and do it all at once :)
  12. Jan 12, 2015 at 8:44 AM
    #5852
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    make sure you solder your wires back behind the head-unit if you can instead of just twisting together with those thumb plugs. Find the right adapter plug for what you have and then solder it all up...
    You're running aftermarket speakers right? are they going to get wired into that amp you posted a page or so ago?
    This is what my adapter setup looked like after I got it all ready to install.
    Sorry if you know all this already. Just making sure you've got the info you need before you tear into it!
    :cheers:
  13. Jan 12, 2015 at 8:48 AM
    #5853
    PLC721
    Patrick
    Chandler, Az
    I have aftermarket speakers hooked up to the stock radio, i am considering having a shop do the whole truck, just because i have no knowledge with sound systems and i want to do it right, i may end up getting a bigger amp and doing something like what Moose1988 has because his truck sounds amazing
  14. Jan 12, 2015 at 8:51 AM
    #5854
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    awww thanks buddy. I still need to finish mine.. :eek:
  15. Jan 12, 2015 at 8:53 AM
    #5855
    SconnieHailer
    Marc
    Yea it gets a bit tedious if you go in deep. If you can get all your speakers wired to a multi-channel amp and then just send the signal to the amp from the head unit you'll have much better power and a cleaner signal headed to your speakers. Where you are (near civilization...lol) i'd say look for a shop and get a quote or find someone who can help ya.
  16. Jan 12, 2015 at 9:10 AM
    #5856
    PLC721
    Patrick
    Chandler, Az
  17. Jan 12, 2015 at 9:40 AM
    #5857
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thats what I have for a setup. Alpine PDX v-9 5 channel powering everything. signal from the HU. all new wiring as well.
    we can get it done...
  18. Jan 12, 2015 at 10:20 AM
    #5858
    PLC721
    Patrick
    Chandler, Az
  19. Jan 12, 2015 at 10:25 AM
    #5859
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
  20. Jan 12, 2015 at 10:32 AM
    #5860
    PLC721
    Patrick
    Chandler, Az
    I just figured since i spend more time driving around now a better system might enhance driver experience
