Noise above 40mph driving me crazy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jmiller78, Feb 23, 2022.
  1. Feb 23, 2022 at 4:32 PM
    Jmiller78
    Jmiller78 [OP] Well-Known Member
    2010 Metallic Gray TRD 115K miles
    Procharger, 2" Leveling Kit, Cali Raised Rock Sliders, 1 1/4" spacers, Armordillo Bull Bar, Color matched bumpers/grille, New Clear Coat, 17" TRD Wheels
    Noise that doesnt change with speed only abruptly comes on above 40ish mph, checked bearings and greased u joints, did not fix. Noise doesnt change with turning or speed. Can not replicate noise when jacked up with all wheels spinning. Engaging 4wd does not change noise.Anyone have any suggestions please?
  2. Feb 25, 2022 at 4:23 PM
    Jmiller78
    Anyone?
  3. Feb 25, 2022 at 4:26 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’ll guess center bearing
    Lil Puke likes this.
  4. Feb 25, 2022 at 4:28 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Engine light is on, OBDII scanned your engine code?
  5. Feb 25, 2022 at 7:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I haven’t a clue bud.
    I can’t tell much from the video.
    Does it do it in 4th gear?
    Is the noise louder/quieter when you are on vs off the gas?
  6. Feb 25, 2022 at 7:36 PM
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    Geez. Sounds like a catalytic converter plugged. Ive done five on different vehicles. Check heat before and after third cat. This would be the one after both exhaust pipes connect. If hot before and cooler after then replace. Have had it twice with no engine codes.
  7. Feb 25, 2022 at 9:03 PM
    Jmiller78
    Light is an O2 Sensor code that keeps recurring, bank 2 sensor 1. The truck makes the noise in every gear going above 40mph. And the noise doesnt get any louder on or off the gas. Ill check the exhause temps, would a plugged cat only make a noise above a certain speed?
  8. Feb 25, 2022 at 9:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the cat was plugged the truck would bog down, lack power and not want to accelerate. It would struggle just getting to 40 mph
  9. Feb 25, 2022 at 9:28 PM
    Whitebutler
    Above certain rpm range, yes it will. Had it with all the ones I've replaced. Could be that the o2 sensor is the one before the pre cat on the passenger side, being bank 2 sensor 1. That could lead to plugged pre cat.
  10. Feb 25, 2022 at 9:31 PM
    Whitebutler
    Nope. My 08 never did. Ran great till 60 ish. My dodge did the same.
    My first gen tacoma was a 2.7 and it got kicked in the nuts really bad. My other dodge work truck and the ford were noticeable but both horrible.
  11. Feb 26, 2022 at 10:15 AM
    Jmiller78
    It doesnt lack in power and has no trouble getting to speed
  12. Feb 26, 2022 at 10:21 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I've owned a lot of vehicles with cats and have never had one fail. On top of that, of all the many friends and family I have with all their vehicles, still no issues.
    How on earth did you go through so many cats on such a variety of makes/models? You must have a huge collection of cars, run crappy fuel or I don't even know what else is possible? o_O
    Whitebutler[QUOTED] likes this.
  13. Feb 26, 2022 at 10:23 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Where does the sound seem to resonate from? Front, middle, or rear of the vehicle?
  14. Feb 26, 2022 at 10:54 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Usually converters fail prematurely when unburned fuel makes it down into the exhaust. Healthy secondary ignition components (plugs, coils) are critical for converter protection
    Whitebutler likes this.
  15. Feb 26, 2022 at 11:45 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Agreed.
  16. Feb 26, 2022 at 11:53 AM
    Jmiller78
    It seems to be coming from the front driver side wheel well if i had to guess, but you know how noises can bounce around inside a vehicle
  17. Feb 26, 2022 at 11:58 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    If you have an old smart phone available maybe move it around the rig (secured however you like) and get some local recording/video of various areas. This might help you pin point your issue, or at least dial in a specific area to focus on in depth.
    Jmiller78[OP] likes this.
