Noise after installing a lift
Discussion in 'Suspension' started by Lezdrivetacos13, May 24, 2020.
  1. May 24, 2020 at 7:42 AM
    Lezdrivetacos13
    Lezdrivetacos13 [OP] Well-Known Member
    Texas
    2021 TRD Off-Road
    1" spacer (front), Helo wheels, 4 dogs.
    So I installed a Bilstein 5100 Coilover lift with AAL in the rear a few weeks ago. I have noticed a noise when I hit some bumps, almost like something is loose but I have checked and nothing is loose and there doesn't appear to be anything that would be hitting or rubbing.
    Any recommendations or suggestions?
  2. May 24, 2020 at 9:59 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    check to see that your spare tire is tight in place and that all u-bolt and other connections are torqued to proper specs.
  3. May 24, 2020 at 10:01 AM
    40ozboys
    40ozboys Well-Known Member
    James
    seattle, Wa
    2019 Tacoma
    3" Kings 35/12.50/17 17x9 SCS F5s
    Check your rear brake lines if you didn't bolt them back down. When i did a lift it was hard to bolt it back in place and had to zip tie so it wouldn't make any noise while driving.
  4. May 24, 2020 at 10:07 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Are you bump stops still in place? Do they make contact before your shocks bottom out?
  5. May 27, 2020 at 5:00 PM
    Lezdrivetacos13
    Texas
    2021 TRD Off-Road
    I don't really know where those are... it is making noise on small bumps. No way they are bottoming out.
