Noise coming from front of engine.
Discussion in 'Performance and Tuning' started by Comatose, Aug 23, 2014.
  1. Aug 23, 2014 at 1:38 PM
    Comatose
    Comatose [OP] You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Hey TW,
    So recently a noise has caught my attention and has been getting louder. It happens when the engine idles at its lowest which make me think its a pulley. Its not the belt and its not idler pulleys (I jumped the gun and bought new pulleys and serp belt and replaced them). Its like a chirping that you would here when something is rubbing wrong like a bad bearing in a pulley. It gets louder when the A/C is engaged which leads me towards the compressor clutch pulley... but when i was in there replacing the idlers, I accidentally spun the fan and there was a slight chirp that happens when the cooling fan pulley rotates slow. I still wonder why the A/C on would make it louder other than there is an extra load on the loop. What do you guys think? :confused:
  2. Aug 23, 2014 at 1:46 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    The radiator fan is making the sound? IMO it should NOT. Is there any stain on the fan shaft? Like the bearing is leaking?
    Not sure about your year. But I never had an auto that the fan clutch makes any noise.
  3. Aug 23, 2014 at 1:47 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    waterpump
  4. Aug 23, 2014 at 2:05 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Do not believe the waterpump would be the noise if he spun the fan with the engine off. If the engine was running--i would agree.
    Is there a fan clutch on his model?
  5. Aug 23, 2014 at 2:54 PM
    Comatose
    Miguel
    San Diego, CA
    I'm on duty today but I will take a vid tomorrow so you guys can hear it. I considered the water pump as well I'm just not sure the noise would be as pronounced under the timing cover. Yes there's a fan clutch.
  6. Aug 23, 2014 at 7:42 PM
    Comatose
    Miguel
    San Diego, CA
    It was just now that I realized that this is not my 92 4runner... The serpentine belt spins the waterpump via the fan pulley doesnt it...
  7. Aug 24, 2014 at 10:13 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  8. Aug 24, 2014 at 10:23 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Just for you......:p
  9. Aug 24, 2014 at 10:28 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    imm go tear shit apart in the truck then :angrygirl:
  10. Aug 27, 2014 at 8:44 AM
    Comatose
    Miguel
    San Diego, CA
    Should be public now.
  11. Aug 27, 2014 at 8:45 AM
    Comatose
    Miguel
    San Diego, CA
    Also the belt squeals now when the engine is cold. And the goes away after about 5 to 10 mins of driving.
  12. Aug 27, 2014 at 9:00 AM
    Comatose
    Miguel
    San Diego, CA
    Tensioner gone bad?
  13. Aug 27, 2014 at 9:09 AM
    BamaToy1997
    Bill
    Navarre, FL
    Since that is what sets the tension for the belt, it could very well cause an issue. Watch the "arm" of the tensioner. It should remain constant. If it jumps around then the tensioner spring is bad and the tensioner should be replaced.
  14. Aug 27, 2014 at 3:48 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Another way to isolate EXACTLY where the noise originates-Use a LONG screwdriver or metal object-put one end to where you believe the noise originates(not on a moving part)-and the other to your ear(of course).
    BAMAToy--knows his stuff!! check his post first!!
    Keep us posted.
  15. Aug 27, 2014 at 5:17 PM
    Comatose
    Miguel
    San Diego, CA
    Whole new issue now... I found where the squealing came from. There is oil all over the front of the engine. I found what looks likes a gasket or seal hanging from around the back of the crankshaft pulley... it's about 4 inches wide... so it can't be the front crankshaft seal. What the hell could it be? No auto parts stores know what it is.
    Manfred likes this.
  16. Aug 27, 2014 at 5:44 PM
    Comatose
    Miguel
    San Diego, CA
    Watching it run the crankshaft pulley has a wobble to it as well... That shouldn't happen should it?
  17. Aug 28, 2014 at 4:51 AM
    Comatose
    Miguel
    San Diego, CA
    If the crankshaft front seal is bad, will that allow a little travel on the crankshaft pulley?
  18. Aug 28, 2014 at 8:05 AM
    BamaToy1997
    Bill
    Navarre, FL
    OK, from what I read in these three quotes, I am guessing one of two things.
    1. The harmonic balancer has had a piece of the dampening rubber come loose from the back side, and has caught up into the front main seal, causing an oil leak.
    2. A piece of the belt, or piece of an older belt, has gotten caught up behind the balancer, and has caught up into the front main seal, causing an oil leak.
    Either way, pull the balancer and inspect it. If the balancer is wobbling, then you should replace it anyway since there is a high risk of throwing a belt.
    Comatose[OP] and Manfred like this.
  19. Oct 27, 2014 at 11:21 PM
    BearWilly
    BearWilly Member
    Will
    Sonora,Ca
    99 Tacoma 4X4...3VZ FE
    Fabtech dirt logic Coilovers, OME 2" lift rear springs and shocks, 2" wheel spacers, some glue, chewing gum and duct tape
    Have you fixed your issue?...was experiencing the same thing with my 99' 2.7L and that "wobble" turned into a sheared woodruff key on my crank and a destroyed oil pump/front crank seal and a chewed up crankshaft...procrastination can be
    detrimental!!!
  20. Nov 20, 2019 at 3:12 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    The video is still private. I could not watch it
