Noise fixed ! 2018 front differential replaced under TSB 0018
Discussion in '3rd Gen. Tacomas (2016-2023)' started by History2008, Oct 9, 2019.
  1. Oct 13, 2019 at 4:31 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Yep, goes away in 4x4.
    And, worrisomely, occurring across more speed ranges and getting louder!! Better get it replaced asap
  2. Oct 13, 2019 at 4:47 AM
    History2008
    History2008 [OP] Active Member
    Then you should ask to let them fix under the tsb although yours is 2019. If not replace the needle bearing with ecgs
  3. Oct 13, 2019 at 4:50 AM
    AKGSD
    Joe
    Alaska
    They claimed the tsb did not apply to my vin - and that it wouldn’t anyway because of the lift. Highly suspect they wouldn’t warranty it
  4. Oct 13, 2019 at 7:23 AM
    History2008
    try another dealer.
  5. Oct 13, 2019 at 7:54 AM
    AKGSD
    Joe
    Alaska
    Worry is, if they decide it’s the bushing, and that they won’t cover it because of the lift - than i’m out around $150 for “diagnosis” on top of whatever they’d charge to rape me & replace it. Cheaper to just buy the bushing and do it
    MtnFisher and Grossomotto like this.
  6. Oct 13, 2019 at 9:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    They may have improved the bearing at the fleet level e.g. 10% of lifted trucks had it before, 2% have it now. Anyway @History2008 has 44,000 miles to verify if the TSB remains effective. :laugh:
    FWIW I'm lifted 2.5" in the front and get no vibes from the diff bearing. CV angles are severe enough that I had to do the boot slide mod to prevent the fins from touching. It definitely isn't a problem affecting all lifted Tacos.
    Grossomotto[QUOTED] likes this.
  7. Oct 13, 2019 at 10:56 AM
    History2008
    Then buy the ecgs and there are a bunch of YouTube on how to do it
  8. Oct 13, 2019 at 10:58 AM
    History2008
    Yeap that's why I decide to keep the ecgs bushing I bought just in case
    3JOH22A[QUOTED] and Grossomotto like this.
  9. Oct 14, 2019 at 5:33 AM
    AKGSD
    Joe
    Alaska
    tell me of this boot slide mod! Mine contacts too!!
    (Super annoying since i specifically asked the shop prior to install if there would be any contact at max articulation, they said no. And yet - cv hits the control arm and the shock, /and/ the upper control arm smacks into the spring!!) (‘course they also said it would be a spring lift and mfers put in blocks...)
  10. Oct 14, 2019 at 6:05 AM
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    I had this TSB done over a year ago & still all good. My diff made noise & when the removed the drivers side CV axle that was damaged as well during repairs. I got a new front differential & drivers side CV axle.
    3JOH22A likes this.
  11. Oct 14, 2019 at 7:54 AM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    So what fresh hell is this? Didn’t know about this one. Is it something to keep an eye on? My 2019 OR is lifted but my diff makes no noise at all. The odometer currently sits at around 12k. Bought it in Feb of this year. Is something affecting the earlier ones?
    davidstacoma likes this.
  12. Oct 14, 2019 at 10:11 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    https://www.tacomaworld.com/threads...differential-bearing-vibration-thread.152173/
    If you aren't getting vibes, leave it alone.
    Sounds like you have a slew of other problems aside from the front diff vibe. Anyway this is an easy mod: https://www.tacomaworld.com/threads/my-cv-boot-mod.190669/
    My installation with clamp size noted: https://www.tacomaworld.com/threads...-3rd-gen-today.399305/page-6334#post-20866194
    AKGSD[QUOTED] likes this.
  13. Oct 14, 2019 at 10:14 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Shocked they agreed to warranty the diff for a lifted truck....
    I know this is 3rd gen, but I replaced my needle bearing on my 2nd Gen with the ECGS bushing and I still get the hum, most noticeably at 80mph......
    I am a mechanical engineer and was dumbfounded at the "designed" clearance between the oem needle bearing and the shaft, never in my life seen that before...... would love to listen to the explanation behind it....
  14. Oct 14, 2019 at 10:16 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    The noise will come back even with a new diff. unless it has the ECGS bushing installed,give it some time.
  15. Oct 14, 2019 at 10:22 AM
    #35
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Lemme know if u wanna get rid of it :thumbsup:
  16. Oct 14, 2019 at 10:23 AM
    #36
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    My 17 is lifted and never had this issue. I have a unicorn
  17. Oct 14, 2019 at 10:24 AM
    #37
    johnnyjunk
    johnnyjunk Lurk more, learn more.
    The Great PNW
    2016 Tacoma TRD Off-Road
    I had my front diff replaced under warranty back in 2016. Was great for about 150-200 miles and the vibes/noise came back. Put in the ECGS bushing and have no issues since.
  18. Oct 14, 2019 at 3:58 PM
    #38
    bzzr2
    bzzr2 Well-Known Member
    Lol ya same here, 2018 with Eibach lift and no front diff problems, last Tacoma was a reg cab 2009 with OME lift and didn’t have this issue either. It certainly is not something that affects all of these trucks. Wonder if there are different part manufacturers making the diffs or bushings... i suggest this because the 4cyl trucks had clutches from two different manufacturers, one was problem free the other was a problem, learned this from having the problem part in the 2009... anyway just a though for the haters to shit on!
  19. Oct 14, 2019 at 6:37 PM
    #39
    History2008
    well, honestly speaking, I know a lot of people have faith in this ecgs, but it is $60 kind of expensive.
    Anyway, I did the wheel alignment yesterday, and sure enough, the alignment was pretty bad after they replace the front diff. Now it runs so smoothly on highway.
  20. Oct 14, 2019 at 7:09 PM
    #40
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I wish someone would take accurate measurements of the ECGS. My machinist buddy might be able to help me make it cheaper.
