Noise fixed ! 2018 front differential replaced under TSB 0018
Discussion in '3rd Gen. Tacomas (2016-2023)' started by History2008, Oct 9, 2019.
  1. Jan 2, 2021 at 12:39 PM
    #61
    Rawdoggy
    Rawdoggy Well-Known Member
    Any ideas? Headed there now. Said they drove it like 15 miles and no luck.
  2. Jan 3, 2021 at 11:12 AM
    #62
    Geno 17TRD
    Geno 17TRD Well-Known Member
    So the ryhtmic hum or vibration is between for me was 30-40 mph. The key is that it's more audiable when the truck is cold!! I had the head mechanic at the dealer take a ride with me to confirm the noise. He heard it with me and said okay, I hear it and its not normal. They took care of it from there.
  3. Jan 3, 2021 at 6:34 PM
    #63
    Rawdoggy
    Fuck toyota dealerships. They told me F off, went to Subaru traded it in today. Not worth my time. Oh it was cold, probably too cold. And there’s only 1 toyota dealership within 600 miles.
  4. Jan 8, 2021 at 10:15 AM
    #64
    STi and Taco
    STi and Taco Not a Super Hero
    Steven
    Georgia
    '16 Tacoma SR 4x4 Access Cab Black, 2012 Subaru STi Hatchback Black, 1995 Acura Legend L Gold (RIP), 2020 Corolla Hatchback
    Diode Dynamics LED Inerior Lighting https://www.diodedynamics.com/by-vehicle.html?no_cache=1&find=2016-toyota-tacoma-115242 Hella Supertone Horns Some Joe Schmuckitelli Keyless Entry Intermittent Wiper Mod - Thanks to @moe2o4 Cruise Control Mod - Thanks to @moe2o4, again Anytime Back-up and Front Mount Camera Mod - Courtesy of @Logistics91 (amazing customer service helping me get it just the way I wanted it set up) Drawtite Class IV trailer hitch with 7/4 pin connector and P3 Tekonsha Brake Controller RokBlokz Mud Flaps Access Cab Rear Seat Storage Mod - Thanks to @Cagedodger for the original idea. Just modified it to fit my needs. https://www.tacomaworld.com/threads/access-cab-storage-organization.453774/page-4#post-17877877 Method 701 Black Wheels 265-70r17 Nitto Ridge Grapplers Fumoto Drain Valve Weather Tech Floor Liners and Side Window Deflecors Tuxedo TruXport Bed Cover Access Cover Motion LED Light Strip. Mounted 2 in the bed. Air Dam Delete Demello Off-Road Overlander Aluminum Winch Bumper with Baja Hoop and Squadron Sport LED Spots Warn M8000 Winch Silex center console organizer and tray Full Bed and Under Hood LED Lighting A/C Condensation Drain Relocation Rostra Front Heated Seats aFe Power 51-82722 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System (Part #51-82722) Prolightz clear LED fog lights w/ lamin-x overlay Red line Hood struts Diode Dynamics Hi/Low beam HID conversion kit MesoJDM 4 switch cubby panel, 7 switch Center panel and Center console Coin Holder @mesojdm Carhart Gray Front Seat Covers Curtis Class IV receiver B&W Tri-ball hitch King 2.5 Front Coilover/Rear Shock 25001-119/25001-121 Coming Soon: Differential Breather Relocation Mod New tires, can't decide
    So just to confirm it's a rhythmic/pulsating hum/vibration that happens from low speed up to about 40mph, the speed of the hum doesn't' really change all that much with higher speeds either, and then I guess the sound goes away more because of just too much road noise? And if you pop it in 4HI the sound will go away confirming it's the needle bearing?
    Sounds like my issue. But mine only seems to happen when it's really cold outside, like sub 40F and is definitely louder/can feel it in the peddles more at lower speeds and deceleration. I have 1.5in lift in front with King 2.5ext and no lift in the rear with King shocks, so not an aggressive lift at all. On a 2016 4cyl 4x4 SR.
  5. Jan 10, 2021 at 8:02 AM
    #65
    STi and Taco
    Steven
    Georgia
    **UPDATE** drove it yesterday morning when it was around 32F, rhythmic humming/grinding vibration started, so once I got to about 20mph, I put it in 4Hi........noise stopped immediately. At only 48k miles too on the truck. Was going to do front and rear diff oil changes at 50k since I do use 4WD quite a bit hunting and what not. Any one know of a reason I shouldn't wait the 2000 miles until I hit 50k and just do it all at once since some gear oil will come out when I pull the axle out anyways?
  6. Apr 30, 2021 at 10:08 AM
    #66
    jhj561
    jhj561 New Member
    Jay
    los angeles
    2017 Tacoma TRD off road
    bilstein 5100's front & rear. ome 885 coils. 2020 trd pro wheels running stack size falcon a/t's
    It's not the needle bearings fault, it's the side gear floating in the diff. Poor design, they rely on the cv shaft to support the side gear and the only thing supporting the cv joint is the needle bearing. On the right side there is a longer shaft that is supported at the other end, so no problem on the right side. The needle bearing has to do double duty supporting the cv joint axle assembly and the side gear. the noise we are hearing is the side gear and spiders spinning. the noise stops when we engage 4wd because the cv joint spins at the same speed as the diff (except when turning). the correct repair would be to replace the diff with one that has side gears that are supported in the diff. Watch the ECGS video that shows the way the diff in the Toyota is made compared to a Dana unit. Off course the bushing that replaces the needle bearing fixes the problem due to the gained support, but it's a band-aid and the right way to fix it would be to redesign the diff. Who Knows, maybe that is what Toyota did in the new front unit that is installed in t sb 0011-18. The end.
  7. May 3, 2021 at 1:04 PM
    #67
    stonerstaniel
    stonerstaniel skiddlybop
    Austin
    Alabama
    2018 Super White DCSB SR5, 33" BFG KM2s on 17" TRD SEMAs
    put the ecgs bushing in. I got a new diff too and then drove for about 2 weeks before the brand new needle bearing shit the bed again. took it to my guy and had the ecgs put in the new diff. No problems, just drove it for 14 hours.
