Noise from driver side front tire
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Aug 7, 2013.
  1. Aug 7, 2013 at 9:42 AM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Just got my tires rebalanced and rotated (truck had no issues going in).
    When I drove it off the lot, noticed a swishing sound (chsh... chsh... chsh...) coming from the passenger front tire. Its a regular sound that increases with speed. No sound at low speed (0-5mph).
    I thought it might be the brake dust shield scraping the rotors but they looked good.
    I had to tighten the spacer lugs so while I had the tires off, I inspected everything. No sound when I rotated the tires by hand (truck jacked up).
    Could this be a bearing going bad? No abnormal vibes (drive much better after the balance and alignment).
    Or could it be abnormal wear on the tread? When they did the rotation initially, I got more vibes than before so I had to bring it in again. The tech noticed some abnormal wear on the tire (toe-heel) and swiched the sides (driver to passenger) as well.
  2. Aug 7, 2013 at 9:45 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    i have that same sound. ive narrowed mine down to either bad hub or my cv axle needing to be replaced (has a small tear, maybe its making noise since it slung out all the grease?)
  3. Aug 7, 2013 at 3:24 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Well I took it in and it turns out the balancing weights were rubbing the calipers.
