Noise from front drive shaft/cv axle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rambrose1, Nov 14, 2015.
  1. Nov 14, 2015 at 6:33 PM
    rambrose1
    rambrose1 [OP] Active Member
    Fairfax, Virginia
    2006 Tacoma Base 4x4
    While in the process of replacing a snapped lug stud (thanks Mr. Tire), i came across a noise from the drive shaft/cv axle which I've never heard before when spinning the tire/wheel hub. Here is the link, can anyone help diagnose?
    https://www.youtube.com/watch?v=DSOOU9qpksg
    Possibly related? I also have a loud click/pop from the front end when going over bumps and turning, but is not the same noise as in the video above. I will work on getting a video of this noise if anyone thinks they can help diagnose this too.
  2. Dec 12, 2015 at 3:55 PM
    rambrose1
    Fairfax, Virginia
  3. Dec 13, 2015 at 8:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Either a defective worn CV Joint or you have something not fully disengaged in the front differential.
